Already you can add Recent Macros as a dropdown menu to a custom toolbar.kisolre wrote: ↑Sat Jan 01, 2022 5:18 pmThere should be some default place for those macros. Now there is a Macros toolbar with just 4 buttons (adding one more would not take much space) and Macros menu item. Under the menu there is a "Recent macros" submenu. So another menu item there with "selected/shortcut/quick access..." macros that is easily populated would be nice. Same list under a button in Macros toolbar - something like Fasteners "drop down buttons" grouping style with the macros icons.
A button under the macro in addon manager that creates those shortcuts and one under the edit macro dialog.
And since there would be a menu items for those macros one could easily add those to any other toolbar if desired.
Addon Manager Redesign 2021
Re: Addon Manager Redesign 2021
- Snip macro screenshot-b36d8a.png (40 KiB) Viewed 3536 times
A macro related to draft need to go to draft, macro related to sketch need to go to sketch workbench, a general macro .....
I tri to say that if that metadata of a macro not say we're to put, a possible solution is to select the destination workbench/icon when te macro is installed.
when I want to translate the GUI of this new interface on Crowdin, I can not find the wording, like Preference Packs. Are they missing or am I not well searching?
Edit: forget, the error is between the computer and the chair = me.
There is a problem with the translation extraction script, though, so the dialogs aren't being translated correctly right now. I've got a PR in, I want Yorik to review before I commit.
I've just pushed a new PR that adds initial dependency resolution to the Addon Manager. At present it does not actually offer to do the required installations for you (that is the subject of some discussion right now), but it will clearly state a resolved list of package dependencies if Addon authors have specified them in either the old-style "metadata.txt" file, or the new "package.xml" file. It does walk the dependency graph, so the presented list should be complete (that is, if the addon depends on another addon, which depends on another addon, and so forth, the list will show all of them). It cannot do this for Python modules, which are just a flat list of required and optional modules. When using your package manager to install them, their dependencies will be resolved.
This PR also cleans up some of the output in response to various comments above. Your testing is welcome, I probably won't merge it for a few days yet, I need to test it on more platforms.
https://github.com/FreeCAD/FreeCAD/pull/5339
In the German forum (https://forum.freecadweb.org/viewtopic. ... 26#p559026) a user reported a problem with the addon manager:
- on installing the parts_library workbench it fails with
I see here 2 issues:
1. the paths from/to the file should be copied are inconsistent
2. both paths only need user permissions since these are user-specific folders. So it is unclear why it is tried to gain admin privileges just to copy a fil
I am not sure the bug is in parts_library or the addon manager, though.
21:34:19 Traceback (most recent call last):
21:34:19 File "D:\FreeCAD-build\Mod\AddonManager\addonmanager_workers.py", line 1128, in run
21:34:19 self.run_git(target_dir)
21:34:19 File "D:\FreeCAD-build\Mod\AddonManager\addonmanager_workers.py", line 1149, in run_git
21:34:19 self.run_git_clone(clonedir)
21:34:19 File "D:\FreeCAD-build\Mod\AddonManager\addonmanager_workers.py", line 1252, in run_git_clone
21:34:19 utils.symlink(
21:34:19 File "D:\FreeCAD-build\Mod\AddonManager\addonmanager_utilities.py", line 82, in symlink
21:34:19 os_symlink(source, link_name)
21:34:19 OSError: [WinError 1314] The client has no necessary permission: 'C:\\Users\\stoehr\\AppData\\Roaming\\FreeCAD\\\\Mod\\parts_library\\PartsLibrary.FCMacro' -> 'C:/Users/stoehr/AppData/Roaming/FreeCAD/Macro\\PartsLibrary.FCMacro'
The parts library is strange for a number of reasons, but in this case it looks like the embedded macro isn't symlinking correctly. I've sort of shied away from look at the PL because of the real issue (that it can't be an Addon, it's just too big). But I'll try to look into this and see if I can figure out why the symlink is failing. I assume it used to work for this person?
Hi
why not see the macro wiki page (as the workbench addon display the Github page) ?
mario
mario
Hi
OS: Windows 10 (10.0)
Version: 0.20.26761 (Git)
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
Locale: French/Mars (fr_MA)
mario
no problemuwestoehr wrote: ↑Thu Jan 06, 2022 3:42 am In the German forum (https://forum.freecadweb.org/viewtopic. ... 26#p559026) a user reported a problem with the addon manager:
Qt version: 5.12.9
OCC version: 7.5.3
mario
For him and also for me it worked after manually copying the macro file to the folder.
Only when you have admin privileges. The issue is that it tries to gain unnecessarily admin permissions to copy a file.
