[FreeCAD 0.20] a beta release for Windows is available
uwestoehr
Post by uwestoehr »
Dear community, FreeCAD 0.20 with all its great features
https://wiki.freecadweb.org/Release_notes_0.20
is almost ready.
In order to test if everything works as expected after it is installed, we released a beta version for Windows:
https://github.com/FreeCAD/FreeCAD-Bund ... /0.20beta1
Please try it out by installing it like every other program on your computer.
Note: FreeCAD 0.20 will support Windows 7, but only the 64bit versions. 32bit Windows is in general no longer supported by FreeCAD.
Please test if the different workbenches for for you as well as the different addons.
If you encounter any troubles, please report them in this thread.
keithsloan52
Re: [FreeCAD 0.20] a beta release for Windows is available
Post by keithsloan52 »
Any Beta for other OS's especially Mac OS?
Post by Kunda1 »
Special request, please coordinate with other packagers before making/cutting a beta build. That way we can release altogether.
GAZ082
Post by GAZ082 »
ETA for Linux build? I use Archlinux at home.
Edit: nevermind, found it: https://snapcraft.io/freecad-ppd
Post by Kunda1 »
GAZ082 wrote: Sun May 15, 2022 7:12 pm ETA for Linux build? I use Archlinux at home.
It isn't necessary to quote everything uwe wrote. Instead, please limit the quote to what you're responding to. Thanks
Edit: to answer your question. We're working on it.
uwestoehr
Post by uwestoehr »
Kunda1 wrote: Sun May 15, 2022 5:59 pm Special request, please coordinate with other packagers before making/cutting a beta build. That way we can release altogether.
I do. I also wrote weeks ago that this release will happen and it was topic in the developers meeting.
Note that this is a Windows-only build (therefore there is no tag in Git). For Linux and MacOS, you can use the Conda builds to test:
https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
keithsloan52
Testing GDML workbench with FreeCAD 0.20-28872 import of
europavehicle.gdml.txt
(102.11 KiB) Downloaded 70 times
Gives for Object
Image 16-05-2022 at 00.10.jpg (55.18 KiB) Viewed 5499 times
Error 00:03:59
<Part> ViewProviderExt.cpp(1270): Cannot compute Inventor representation for the shape of europavehicle#union_Union_BC_ELM_DS_PROP_STRCTRE_MRK6_A004: Bnd_Box is void
Does not occur for FreeCAD 0.19.2 ( Note 0.19.4 is not available for Mac OS :-( )
OS: macOS 10.16
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
But does for
OS: macOS 10.16
Version: 0.20.28872 (Git)
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * MeshRemodel 1.8919.0
  * ImportNURBS
  * dxf_library
  * InventorLoader 1.3.0
  * workfeature
  * Defeaturing
  * Macro-Vision
  * GDML 1.8.0
  * Manipulator 1.4.3
  * Design456
  * SWPart
  * OpenSCAD_Alt_Import
  * Jupyter
  * 3D_Printing_Tools
  * toSketch
  * Curves 0.3.0
hammax
Post by hammax »
... release
OS: Windows 10 Version 2009
Version: 0.20.27422 (Git)
worked until now.
The actual beta_1 => failed
hpbmo
Post by hpbmo »
After installing this beta release into a new directory, Addon Manager did not start:
Missing dependency.jpg (11.61 KiB) Viewed 5444 times
Edit:
Version: 0.20.28871 (Git)
Hash: 10fa08e87991f87ea714a7026a600800aa74888a
Python 3.8.10, Qt 5.15.3, Coin 4.0.1, OCC 7.5.3
Locale: German/Switzerland (de_CH)
Installed mods:
  * A2plus 0.4.56
  * Assembly4 0.11.10
  * CubeMenu
  * Curves 0.4.2
  * Defeaturing
  * DynamicData 2.46.0
  * ExplodedAssembly
  * fasteners 0.3.40
  * fcgear 1.0.0
  * kicadStepUpMod 10.11.9
  * Manipulator 1.4.3
  * pluginloader
  * sheetmetal 0.2.49
  * Ship 2022.4.11
  * ThreadProfile 1.81.0
Post by Kunda1 »
Everyone that is posting...please add you full About info to your post/feedback/issue thank you!
