B-Spline Constraints: Fully Funded! Thanks everybody!
Re: B-Spline Constraints: Fully Funded! Thanks everybody!
@abdullah admittedly your dilemma is partly caused by my reluctance to try the closest point algorithm. It does seem analysing and modifying the diagnosis is the optimal solution. If you look into the code for tangent to b-spline (not tangent at knot), you'll notice that I have added more parameters which makes it still more complicated (though in the future it may be formalized better as angleviapoint).
- DeepSOIC
Hi everyone! @abdullah has kindly asked me to have a look at this. I have looked at some of the code of the pull-request (jnxd's sketcher-point-on-bspline branch at 44fb105b4d1d6a8aa724e1384dc5ae570894b1fe), but did not compile it, and did not fully read this discussion. Here's my opinion.
I have no serious objections to the current implementation (constraint having the parameter of the point stored as a datum value of the constraint). This is exactly how i think this constraint should be implemented, mainly because finding the distance to a spline given just point coordinates requires significant computational time (numerical solving for the closest point), but also because splines can be periodic and/or self-intersecting, so finding such point is (in general) ambiguous.
I have noticed a few minor things.
1) ConstraintPointOnBSpline has a std::vector<double> factors member, which can be replaced with just a single non-array variable in constraint computations (as far as i can see).
2) these's one comment in the code that point-on-bspline constraint in driving mode does not make sense. My opinion is that it does absolutely make sense if the value of the parameter is made available for editing/expression in the UI. Think of it as non-driving = a bead on the spline that is free to slide along, driving = a crimp affixed to a particular place of the spline.
3) the lack of dynamic segment hopping while the solver is working may cause a mis-solution. Allowing the hopping will require to declare all of the poles (and weights and knots) as dependent parameters of the constraint, causing a lot of extra grad runs, possibly causing a significant drop in performance for splines with many segments. I'm not sure what is more important here, correctness or performance.
Hi @DeepSOIC, nice to hear your opinion.
Re: 2) I am aware of that possibility. Essentially making it driving creates a "zero-multiplicity" knot at that parameter and constrains it to be coincident to the point. However, the comment was there to say doing so won't have any particular use to the user. However if there is a compelling case and we allow for it to become driving, we must not add it to the driven constraints list since it still has a practical use (though we could change the code such that driven parameters may still be used as a solver parameter).
Re: 3) This is indeed a dilemma. However, the performance penalty with grad depends on whether or not the function is called for every parameter (for example, a coordinate of an end point of a line being called for an unrelated point-on-circle constraint). If it is called and we just return zero, we can just discard any control points that do not apply to the current segment (with the value of the spline param used to calculate the segment every time). However if it does result in a dense matrix (albeit with most elements within it set to zero) the performance penalty is indeed significant.
Re: 1) I'll take a look. I think I decided to keep it as such for the sake of consistency with the rest of the implemented constraints. Given that the number of nonzero factors won't be too many (degree+1), it shouldn't be (or hasn't been) much of a penalty. That said they were still "training wheels" and it's time to remove them.DeepSOIC wrote: ↑Thu Dec 29, 2022 12:16 am I have noticed a few minor things.
- adrianinsaval
I can't make a line to be tangent to a knot and make the endpoint coincident at the same time, is this expected?
@adrianinsaval endpoint of the line segment to the knot or end points of the b-spline?
- adrianinsaval
endpoint of the line to the knot
I can confirm this is an issue. @abdullah this is one thing we need to look back into. I think the implicit point-on-line constraint (part of tangent-at-knot) is interfering with any intended coincident constraint. I can see why this would make the constraint "redundant", but from my observation this is leading to "solution does not converge".
I think there might be two forces at play: 1) the internals of the tangency that prevent the line endpoint from converging to the knot position (if the line is first made tangent to the knot and the the end point is tried to be made coincident), and 2) the fact that the selection of the tangency (point-to-line) is not adequate.jnxd wrote: ↑Mon Jan 09, 2023 6:22 pmI can confirm this is an issue. @abdullah this is one thing we need to look back into. I think the implicit point-on-line constraint (part of tangent-at-knot) is interfering with any intended coincident constraint. I can see why this would make the constraint "redundant", but from my observation this is leading to "solution does not converge".
For 1), it may be possible to "modify" what we introduced when trying to avoid the lack of convergence of the first version.
For 2), I think we have a case that we have not considered, point-to-point tangency with a line endpoint and the knot. That is what we should use to solve the legit partial redundancy message. That one should add internally a concident as opposed to a point on object. For lines and endpoints there is a constraint swapping mechanism (constraint substitution) to make user's life a little bit less miserable, a similar one should be then implemented for knots and line endpoints...
Does it make sense to you?
Yes. I mean that one. I think that mechanism may be preventing the point to converge here. Could you check that?
