B-Spline Constraints: Fully Funded! Thanks everybody!
uwestoehr
Re: B-Spline Constraints: Looking for Crowdfunding
Post by uwestoehr »
chrisb wrote: Tue Aug 16, 2022 6:08 pm I like Beziers which I know from Inkscape, but I haven't seen any request for years to add them to the Sketcher.
You can already create Bézier curves:
- add a spline consisting of 3 points (start, end, and a control point). The result is a quadratic Bézier curve.
- add a spline consisting of 4 points. The result is a cubic Bézier curve.
- for higher curve degrees, create a cubic Bézier and increase the degree.
B-splines are mathematically created using another base for some reasons, see
https://wiki.freecadweb.org/B-Splines#Basis
for more details, but the result is nevertheless a Bézier. You can check this out using a math program. Create a quadratic B-Spline and Bézier using the same point coordinates and the curve follows the same path.
jnxd
Post by jnxd »
uwestoehr wrote: Thu Sep 01, 2022 8:56 pm
You can also press D when making the spline, enter the degree, and put degree+1 points.
Indeed going forward I am inclined to work by treating these "minimal" b-splines as bezier curves, so that there is no need to implement them separately.
My latest (or last) project: B-spline Construction Project.
jnxd
Post by jnxd »
CODING UPDATE: 03 September 2022
Development on knot-constraints has been slow this week, but I just fixed a major issue: driving constraints can now be set on knots.
vase-with-knot-constraints.FCStd
(10.73 KiB) Downloaded 39 times
You can test the feature now by building from the relevant branch on my fork (or, Linux users can install the snap following these instructions). Let me know if this by itself satisfies a use-case, or if there is something more needed (like tangency at knots, non-uniform knots, etc).
Known Issues:
  1. Start point of a periodic b-spline (which is also end point) cannot be dragged, and any constraints set on this point will fail. [EDIT 7 Sep 2022: This is now resolved]
  2. The "Toggle driving" command can turn any constraint on knots into reference, but cannot make them driving (this is not unique to knots).
  3. Of course, rational B-splines are still not supported yet.
Congrats for this very remarkable step!
jnxd
Post by jnxd »
chrisb wrote: Fri Sep 02, 2022 10:09 pm Congrats for this very remarkable step!
Thanks! please give it a go if you have a project that could use this.
Post by Kunda1 »
Snap build in progress for testing purposes. Once build is complete, install instructions will be added here.
Edit: https://github.com/FreeCAD/FreeCAD-snap ... 1236113658
marthinwurer
Post by marthinwurer »
Fantastic, this feature will open a lot of doors. I just threw $100 in the pot on github sponsors, and I'll throw more in with my next paycheck. My main goal is to be able to define airfoils from points to be able to 3d print RC planes and model rockets. I'll test out that snap and see how it goes!
user1234
Post by user1234 »
Nice!
Greetings
user1234
jnxd
Post by jnxd »
marthinwurer wrote: Sat Sep 03, 2022 9:16 pm Fantastic, this feature will open a lot of doors. I just threw $100 in the pot on github sponsors, and I'll throw more in with my next paycheck. My main goal is to be able to define airfoils from points to be able to 3d print RC planes and model rockets. I'll test out that snap and see how it goes!
Thanks, @marthinwurer! Your post back in July was the last thing to inspire me to start this crowd funding, so your support means a lot. Please do not feel compelled to sponsor any more than you had planned.
jnxd
Post by jnxd »
FUNDING UPDATE: 6 September 2022
Another Tuesday another update
Since the release, I have received:
Github:
One time: $235
Monthly: $7
Liberapay: $89 + €170 = ~$259
Additional:
Pledged: $200 (upon implementation progress towards stage 2) + €250
All in all, this amounts to up to ~$965/$3000 towards this project, assuming it takes 3 months to complete.
Just $35 to reach $1000! A couple people have mentioned they plan to donate shortly, so that sounds like a win. Which is just about time: barring any bugs, I expect to be able to support rational B-splines by the end of next week, at which point it will be ready for PR.
