PS: I will implement the corresponding Draft function later next week (hopefully )
PyObject* BSplineCurvePy::buildFromPoles(PyObject *args)
PyObject* obj;
int degree = 3;
PyObject* closed = Py_False;
if (!PyArg_ParseTuple(args, "O!|O!i",&(PyList_Type), &obj, &PyBool_Type, &closed, °ree))
return 0;
try {
Py::List list(obj);
TColgp_Array1OfPnt poles(1, list.size());
Standard_Integer index = 1;
for (Py::List::iterator it = list.begin(); it != list.end(); ++it) {
Py::Vector v(*it);
Base::Vector3d pnt = v.toVector();
poles(index++) = gp_Pnt(pnt.x,pnt.y,pnt.z);
if (poles.Length() <= degree)
degree = poles.Length()-1;
TColStd_Array1OfReal knots(1, poles.Length()+degree+1-2*(degree));
TColStd_Array1OfInteger mults(1, poles.Length()+degree+1-2*(degree));
for (int i=1; i<=knots.Length(); i++){
knots.SetValue(i,(double)(i-1)/(knots.Length()-1));
mults.SetValue(i,1);
mults.SetValue(1, degree+1);
mults.SetValue(knots.Length(), degree+1);
Handle_Geom_BSplineCurve spline = new Geom_BSplineCurve(poles, knots, mults, degree, (closed == Py_True));
if (!spline.IsNull()) {
this->getGeomBSplineCurvePtr()->setHandle(spline);
Py_Return;
else {
Standard_Failure::Raise("failed to create spline");
return 0; // goes to the catch block
catch (Standard_Failure) {
Handle_Standard_Failure e = Standard_Failure::Caught();
PyErr_SetString(PyExc_Exception, e->GetMessageString());
return 0;
import FreeCAD, Part
poles = [FreeCAD.Vector (-2.43607, -1.53508, -5.57219), FreeCAD.Vector (-2.03255, -0.403658, -4.22005), FreeCAD.Vector (-0.398255, 0.859922, -2.87439), FreeCAD.Vector (0.808547, 0.291087, -3.75003)]
spline=Part.BSplineCurve()
spline.buildFromPoles(poles, False, 3)
Part.show(spline.toShape())
