Extended selection window
Re: Extended selection window
i have remembered we have been talking with bernd about something similar in another topic and have posted this video, maybe it can help to get some ideas https://www.youtube.com/watch?v=I0V_8EGYHgU
With Sketcher open, selecting a Constraint from the Constraints widget causes it to appear in the Selection Window.yorik wrote:You can also double-click an item, which does the same as the "select only" option.
That's it for now, but it can fo course be extended further.
In the Selection Window, we can right-click on that Constraint to get the "Select Only / Deselect / Zoom Fit / Go to Selection" pop-up window.
I'm wondering:
If the user selects "Zoom Fit" from the pop-up, could the Zoom Fit be applied to a Coincident Constraint? Or, in the case of a Coincident Constraint, maybe zoom in to 25% fit at so there's not just one big solid red circle in the 3D window?
Coincident Constraints seem to be the only ones now that can at times be difficult to find, and maybe this could help? If a user has Conflicting Constraints the user can click on the (click to select) message to have FreeCAD select them in the Constraints window. From there the user can select a Constraint from the list and it appears in the Selection Window. What I'm referring to is that from here the user can right-click on the Constraint in the Selection Window and select "Zoom Fit" to have FreeCAD Zoom Fit (but at maybe 25% of the whole screen) to see the location of that Coincident Constraint.
It would be really nice if hovering the cursor over a Constraint in the Selection Window caused it to be highlighted in the 3D window too, as is done with items in the Elements widget...
Might be a good idea indeed, but that could also be implemented directly in the sketcher (in the constraints list).
I your idea is even better!yorik wrote:Might be a good idea indeed, but that could also be implemented directly in the sketcher (in the constraints list).
At least in all properties which uses strings as values. Is there any chance to get that? Checked src/Gui/SelectionView.cpp but my C++ is just poor ...bernd wrote:... Would it be possible to have a switch to search in all Properties instead only the label? I'd be fine with that one allready.
Yes it could be done of course, just not sure how yet...
Looks great so far, i am really impressed, good job yorik.
May i suggest adding "invert selection" to the options ?
I know that from solidworks and quite often you have a situation where you
like to change properties of all objects except for one specific.
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
hm good idea too... Anyway this topic will be good to gather all ideas to extend that window.
