FEM Python coding standard
PrzemoF
Re: Python coding standad [WORK IN PROGRESS]
Post by PrzemoF »
bernd wrote:
PrzemoF wrote:...
My proposition:
1. Fem* for general python modules,
2. ccx* for CalculiX related stuff
3. _Command* for GUI commands (underscore suggest internal use only).
Most of FEM python modules match this convention already
I'm with you here.
How about Python ui files? Should they be moved together with cpp ui files in a separate directory like the icons ?
It makes no difference for me to be honest and moving them might cause some problems in CMake files and downstream for package maintaners. I'd leave them for now unless someone is willing to move them :-)
Re: Python coding standard [WORK IN PROGRESS]
Post by bernd »
microelly2 wrote:I had some requirements for handling macros and want remember this here
A macro should have at least theese meta information for autogeneration
No Licence ?
Post by bernd »
bernd wrote:... How about Python ui files? Should they be moved together with cpp ui files in a separate directory like the icons ?
ok
PrzemoF
Post by PrzemoF »
__Comment__ = 'Imports and scales an Airfoil in the form of a Draft Wire (DWire) or Basic Spline (BSpline)'
__Web__ = "http://forum.freecadweb.org/viewtopic.php?f=22&t=5554"
__Wiki__ = "http://www.freecadweb.org/wiki/index.php?title=Macro_Airfoil_Import_%26_Scale"
__Icon__  = "/usr/lib/freecad/Mod/plugins/icons/airfoil.png"
__Help__ = "start the macro and follow the instructions"
__Author__ = "quick61"
__Version__ = '2.1'
__Status__ = 'stable'
__Requires__ = 'freecad 0.14.3706'
__Communication__ = 'your email adress or yourgit or something else'
backref: viewtopic.php?f=21&t=10905&start=20#p91086
The macro manager is/will be in the master branch of FreeCAD or it's a separate piece of code?
microelly2
Post by microelly2 »
the plugin manager is still standalone. I want to have some standards for community plugins to improve the possibility to integrate them.
Until now it needs still extra work to integrate the macros,
so some conventions must be accepted to simplify and automate the process.
After this the plugin manager can become integrated and a standard plugin database can hold the information about community macros and workbenches.
PrzemoF
Post by PrzemoF »
OK, I'll add id in a separate section with macro requirements to the opening post.
microelly2
No Licence ?
Macros are stored in gits and have a Licence file inside (until now ;) ).
My focus was:
If there is a published macro I can support the installation and updates for freecad users.
Mostly the licence is in the header of the file with the meta info and can be displayed.
But of course a link to the licence file/message can be integrated into the install dialog.
Post by wmayer »
The general rule is to follow PEP8 [1] and use flake8 [2] (or anything that allows PEP8 checks) to enforce it.
Is there also a way to make code Python 3 ready, i.e. to force e.g. write print ("test") instead of print "test" ?
PrzemoF
Post by PrzemoF »
In a way yes, but flake8 has to be run with python3 [1]:
$fedora:/home/przemo/software/FreeCAD/freecad
$ python /usr/bin/flake8 --ignore=E265,E501 src/Mod/Fem/FemTools.py <-- clean run on python2
$ python3 /usr/bin/flake8 --ignore=E265,E501 src/Mod/Fem/FemTools.py
src/Mod/Fem/FemTools.py:242:71: E901 SyntaxError: invalid syntax <-- error on python3
The line 242 is python2 compatible, but not python3 compatible:
            print "Unexpected error when writing CalculiX input file:", sys.exc_info()[0]
--ignore=E265,E501 is to ignore line length and invalid style of comments
P.S. For fedora users there is a package python3-flake8, so it's enough to run:
$ python3-flake8 --ignore=E265,E501 src/Mod/Fem/FemTools.py
[1] http://stackoverflow.com/questions/2360 ... r-python-3
For those experimenting with phabricator: arc lint config for python2/3 checks:
$ cat .arclint
    "linters": {
        "flake8-python2.7": {
            "type": "flake8",
            "bin": "/usr/bin/flake8",
            "include": "(\\.py$)",
            "exclude": "(^src/3rdParty/)",
            "severity": {
                "E265": "disabled",
                "E501": "disabled"
        "flake8-python3": {
            "type": "flake8",
            "bin": "/usr/bin/python3-flake8",
            "severity": {
                "E265": "disabled",
                "E501": "disabled"
makkemal
Post by makkemal »
I think the ui and icon files should be in a separate subdirectory /Mod/Fem/ and not the same location as the CPP files. It makes development easier for a beginner.
