Prescribed Displacement Testing and Advice
makkemal
Postby makkemal » Mon Oct 19, 2015 7:33 am
I have managed to get a displacement constraint working using only python. (My first attempt so I expect I still have some work)
I am not committing it to git-hub yet since some of the coding only made sense for me to get the features working.
That and I am not sure I know how to do this correctly yet.
For instance is update in InitGui.py does not make sense for the global project but was necessary for me to do to get a displacement icon in without compiling.
The coding is based on development version 0.16.5560
Just copy the code (attached) below into the /MOD/FEM directory and you will have a displacement Icon and a UI for selecting it.
This constraint although only in global coordinates make it possible to model symmetry, rolling constraints etc.
Can someone please advise me how to get this code into the main repository without damaging the original code ?
Regards
Michael
[img]
[/img]
FEM_prescribed.zip
(41.03 KiB) Downloaded 71 times
Re: Prescribed Displacement Testing and Advice
Postby bernd » Mon Oct 19, 2015 7:43 am
Cool. I'll give it a try.
It is a pitty you did not commit it to a git hub account. It would make live for us much easier if you would create an own github account and commit it to that account.
Would you copy your FreeCAD help info. Just to know on which FreeCAD commit version the code should work.
makkemal
Postby makkemal » Mon Oct 19, 2015 7:54 am
I have created an account but its a whole new learning curve of how to get code committed, I will do it but for now I have no idea of what I am doing on github
Postby bernd » Mon Oct 19, 2015 8:39 am
Ahh I see, I had the same problem when I started FreeCAD development one and a half year ago. Gave your code a short try. Yeah cool. We should for sure some how integrate this in FEMWB.
Regarding github, we could gide you if you want ?
Do you compile FreeCAD yourself or did you make all the changes in the installation path off FreeCAD (FreeCAD.ConfigGet("AppHomePath") + 'Mod/Fem') ?
Which FreeCAD commit is your code based on?
makkemal
Postby makkemal » Mon Oct 19, 2015 9:10 am
I did not compile anything. I gave up on compiling a few weeks ago, a way to steep learning curve.
I downloaded and used the windows 64 pre release 0.16.5560
I then did all the updates in the Mod/FEM dir
The problem I see with the commit is that I did override some C++ with python like the InitGui.py
This is to be able to test without compiling.
So yes please guide me on howto commit this code
Postby bernd » Mon Oct 19, 2015 9:21 am
makkemal wrote:So yes please guide me on howto commit this code
Would you post your FreeCAD --> help --> about
What's your github username?
Do you have git installed on windows?
Postby wmayer » Mon Oct 19, 2015 10:17 am
bernd wrote:Would you post your FreeCAD --> help --> about
makkemal wrote:The coding is based on development version 0.16.5560
Postby bernd » Mon Oct 19, 2015 10:23 am
and viewtopic.php?t=5308 the other way around, but I do not know this ?!
Postby wmayer » Mon Oct 19, 2015 10:47 am
The hash number to 5560 must be 32367b1744c5939027a9ed97a7231fe38eeb919b.
I am on 5759 which is 337a36ceb89ce29dcbcc288257c37f34546a534e. With
git rev-list 337a36ceb89ce29dcbcc288257c37f34546a534e > test.log
I get a text file with all commits. Since the order of chronology is from bottom to top you have to go to line (5759 - 5560) + 1 = 200 which then is the above hash number.
Postby bernd » Mon Oct 19, 2015 10:57 am
Thanks werner !
git rev-list 32367b| wc -l
gives 5558
It is bb05d1759614b55a2e8832f8628bce6add609ad4
git rev-list  bb05d1| wc -l
gives 5560
EDIT: https://github.com/FreeCAD/FreeCAD/tree/bb05d1
