test request, multiple material
PrzemoF
Re: test request, multiple material
Postby PrzemoF » Wed Oct 28, 2015 1:00 pm
Nice macro! Could you something like "this line":
        output ='Error executing {}'.format(command)  <-- this line
        try:
            output = subprocess.check_output([command, '-1'], shell=True, stderr=subprocess.STDOUT,)
        except:
If gmsh crashes the macro crashes as well with error saying that output is not assigned:
gmsh  /tmp/tmpPbCumz.step  -3 -format unv  -o /tmp/Box_Mesh -format unv   -algo netgen  -clmax 5.00  -order 2     -string "Geometry.OCCConnectFaces = 1;"
*** Error in `gmsh': malloc(): memory corruption: 0x0000000001c01eb0 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x77a8d)[0x7f3e97f96a8d]
/lib64/libc.so.6(+0x8112e)[0x7f3e97fa012e]
/lib64/libc.so.6(__libc_malloc+0x6e)[0x7f3e97fa246e]
/lib64/libstdc++.so.6(_Znwm+0x18)[0x7f3e98584158]
/lib64/libstdc++.so.6(_Znam+0x9)[0x7f3e985841f9]
/lib64/libngmesh.so.0(_ZN6netgen10BASE_TABLEC1Ei+0x33)[0x7f3e95f02833]
/lib64/libngmesh.so.0(_ZN6netgen15IdentificationsC2ERNS_4MeshE+0x52)[0x7f3e95e961b2]
/lib64/libngmesh.so.0(_ZN6netgen4MeshC1Ev+0x46f)[0x7f3e95e54f5f]
/lib64/libGmsh.so.2.9(_ZN5nglib10Ng_NewMeshEv+0x33)[0x7f3e98fd3723]
/lib64/libGmsh.so.2.9(_Z20buildNetgenStructureP7GRegionbRSt6vectorIP7MVertexSaIS3_EE+0x44)[0x7f3e98e4f6f4]
/lib64/libGmsh.so.2.9(_ZN11meshGRegionclEP7GRegion+0x434)[0x7f3e98e50714]
/lib64/libGmsh.so.2.9(+0x56c1e3)[0x7f3e98de41e3]
/lib64/libGmsh.so.2.9(_Z12GenerateMeshP6GModeli+0x1143)[0x7f3e98de6c43]
/lib64/libGmsh.so.2.9(_ZN6GModel4meshEi+0x9)[0x7f3e98c81d59]
/lib64/libGmsh.so.2.9(_Z9GmshBatchv+0x2fa)[0x7f3e98ac51ea]
gmsh(main+0x92)[0x400f82]
/lib64/libc.so.6(__libc_start_main+0xf0)[0x7f3e97f3f700]
gmsh(_start+0x29)[0x4010b9]
Error!!, sorry..Traceback (most recent call last):
  File "/home/przemo/.FreeCAD/FEM_GMSH_Mesh_bhb.FCMacro", line 230, in proceed
    FreeCAD.Console.PrintMessage(output)
UnboundLocalError: local variable 'output' referenced before assignment
Postby bernd » Wed Oct 28, 2015 1:14 pm
Have you been successful?
PrzemoF wrote:Nice macro! Could you something like "this line": ...
Sure thanks for reporting. The macro is not finished yet. The connectfaces and sewfaces should be auto too. Ahh and I need to add this stuff viewtopic.php?f=18&t=10732&start=10 but all that mesh stuff is another part of the story ...
PrzemoF
Postby PrzemoF » Wed Oct 28, 2015 1:33 pm
Not really, but it's a gmsh problem - it keep crashing. I'll try again later on another computer.
Postby bernd » Wed Oct 28, 2015 1:55 pm
PrzemoF wrote:Not really, but it's a gmsh problem - it keep crashing. I'll try again later on another computer.
I could not resist ...
wood-steel-fem1.fcstd
(104.38 KiB) Downloaded 24 times
PrzemoF
Postby PrzemoF » Wed Oct 28, 2015 1:59 pm
Thamks! :D
What version of gmsh do you use? I have 2.9.3
Postby bernd » Wed Oct 28, 2015 2:00 pm
- In FreeCAD Make a coumpound of the two boxes
- export to step
- start gmsh gui
- in gmsh gui Tools --> Options --> Geometry --> Tab Genereral --> activate "Cut and merge faces"
- load step
- in tree --> click on mesh --> 3D
- File --> save as --> export to unv
- import into FreeCAD
2.10.0
PrzemoF
Postby PrzemoF » Wed Oct 28, 2015 2:58 pm
Thanks! I think we can get something similar (tha same?) with the gmsh macro and custom gmsh options set to:
-string "Geometry.OCCConnectFaces=1;"
Pushing a piece of steel into ABS block:
abs-steel-fem.fcstd
(131.28 KiB) Downloaded 29 times
Postby bernd » Wed Oct 28, 2015 3:23 pm
PrzemoF wrote:Thanks! I think we can get something similar (tha same?) with the gmsh macro and custom gmsh options set to:
The same. Thats exactly what it needs to connect the solids of compound and what is included in my version of the macro.
PrzemoF wrote:Pushing a piece of steel into ABS block:
cool.
Have you been able to repeat the error you had during selection ? I do not get it !
teobo
Postby teobo » Wed Oct 28, 2015 4:22 pm
Hi guys,
I see you've got fun playing. (:
@bernd maybe a short tutorial on the multiple material gui handling, or enhancing our tut.
-maybe a tooltip_ would be better than nothing_.
-maybe a gui tut for the frequency/state of usage of the frequency fem as well, guess it is time variant mechanical analysis, is not it?
Then some iges house from do not know where, compound it, material is already in hopefully, then you apply some sinus boundary forces and ready is your earthquake simulation?
...rumble, rumble ...
Have fun
Postby bernd » Wed Oct 28, 2015 4:43 pm
@tebeo: see that post viewtopic.php?f=18&t=12995#p104189 and of course all other post in the thread.
If you have special problems feel free to ask or post the file you have problems with. Any testing of the multiple materials is highly appretiated.
