Lattice workbench [updated Polar Array]
DeepSOIC
Re: Lattice workbench [in development]
Postby DeepSOIC » Wed Oct 28, 2015 10:51 pm
A few new tools are available:
* Individual placement (like an array of just one element)
* ArrayFromShape: can convert Draft Arrays to lattice arrays (parametric), which can then be applied as many times as desired. [very new, may be very buggy]
* Apply tool: put real shape into placements of a lattice array
* compose (the one that was on two last teasers): similar to Apply, but enumerating children in a compound.
ArrayFromShape applied to a Draft PathArray of spheres
lattice arrayFromShape.png (138.39 KiB) Viewed 1625 times
DeepSOIC
Postby DeepSOIC » Fri Oct 30, 2015 12:03 am
Fisrt project done with some usage of Lattice wb.
PMT lattice teaser.png (229.82 KiB) Viewed 1596 times
https://drive.google.com/file/d/0B9lBm- ... sp=sharing
Lattice tools that came handy:
* Bounding boxes (they are very handy for attaching sketches, and they have stable face numbering)
* Lattice Placement/Lattice Apply: equivalent of Draft Clone, but moves as the original is moved (unlike clones, which stay where they are if original is moved). Also helped very much to quickly bring the model modeled in XZ plane to XY plane for plating.
That was a tight fit. I had to modify the model to fit it.
* Downgrade, Fuse compound. Turned useful when making notches that align two halves.
Postby bernd » Sat Oct 31, 2015 12:54 pm
DeepSOIC wrote:...
2. Thinking on a analysis tool. Because it is impossible to figure out the content of shape (a compound of faces looks exactly like a solid cube). I think of a window in task pane, where object structure will appear whenever it is selected. Like so:
Compound:
    Compound:
        Face
        Face
    Compound:
        Solid
        Vertex
Alternative is a separate tool that uses graphviz (can be much easier as well as much harder than the first variant)
Any update on this? Something really useful for me too.
DeepSOIC
Postby DeepSOIC » Sat Oct 31, 2015 12:57 pm
bernd wrote:Any update on this? Something really useful for me too.
Nope, thanks for reminding. I almost forgot.
DeepSOIC
Postby DeepSOIC » Sat Oct 31, 2015 3:12 pm
Done and pushed to github! Lacks icon so far...
lattice info tool.png (251.86 KiB) Viewed 1524 times
DeepSOIC
Postby DeepSOIC » Sun Nov 01, 2015 5:21 pm
Feature announcement: string array
lattice shapestring.png (29.02 KiB) Viewed 1491 times
DeepSOIC
Postby DeepSOIC » Sun Nov 01, 2015 8:34 pm
I have made a new marker shape. Hopefully, this one is a bit easier to catch the orientation by looking at it, compared to previous one.
triplus
Postby triplus » Sun Nov 01, 2015 10:48 pm
Did some quick tests and it is looking good.
DeepSOIC
Postby DeepSOIC » Mon Nov 02, 2015 11:43 pm
Linear array was just implemented, so I though - why not try creating a Pi tower I recall someone was making...
pi tower.png (34.33 KiB) Viewed 1433 times
DeepSOIC
Postby DeepSOIC » Fri Nov 13, 2015 7:59 pm
Another teaser.
I have created a small model of a solar tracking powerplant. The main aim was to orient the mirrors, which turned out to be much trickier than I expected. But I got it.
The model is parametric: number of mirrors can be changed; tower can be moved, direction of sunlight can be changed.
SolarPlant 3.png (262 KiB) Viewed 1371 times
SolarPlant 3.FCStd
(238.15 KiB) Downloaded 60 times
I'm thinking of making a tutorial based on this model. The process of deriving mirrors orientation from incoming and reflected directions is the most tricky part, all the rest is pretty easy.
I also think of making a special tool: averaging aiming. I already have orientation averaging, but it averages overall orientations, not just X axes, so it didn't do what I expected. Now I did a workaround via a center of mass of two fused spheres.
For those who just want to have a play:
Plm-Sunlight sets sunlight direction
