[Fixed] Expressions: crash when object.Name == "Placement"
DeepSOIC
Post by DeepSOIC »
Hi!
The bug was narrowed down from a crash in Lattice wb reported by @Dim, here: viewtopic.php?f=3&t=13906&start=10
1. new document.
2. run:
o = App.ActiveDocument.addObject("Part::FeaturePython","Placement")
3. Select the new feature. FreeCAD hits an assert, then crashes.
Note: on Windows, it crashes only in debug build. Release build seems to swallow the problem, not sure why.
OS: Windows 8.1
Version: 0.16.6207 (Git)
Build type: Debug
Branch: (detached from abdullah/hyperbola_2016)
Hash: f80e07e04cc09cef611768a11fdbb7799460e336
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
Re: [bug] Expressions: crash when object.Name == "Placement"
Post by wmayer »
The assert is triggered in
void ExpressionBinding::bind(const App::ObjectIdentifier &_path)
    const Property * prop = _path.getProperty();
    Q_ASSERT(prop != 0);
    path = prop->canonicalPath(_path);
    //connect to be informed about changes
    DocumentObject * docObj = path.getDocumentObject();
    connection = docObj->ExpressionEngine.expressionChanged.connect(boost::bind(&ExpressionBinding::expressionChange, this, _1));
FYI, in a release build an assert is always a NOP (no operation).
eivindkvedalen
Post by eivindkvedalen »
wmayer wrote:The assert is triggered in
But then we should have an immediate crash below, because prop is 0. Anyway, the issue is another case where the property is not resolved properly. I think I should be able to fix this during the weekend.
Eivind
eivindkvedalen
DeepSOIC wrote:Hi!
1. new document.
2. run:
Please try https://github.com/eivindkv/free-cad-co ... ns_fixes_8
Eivind
DeepSOIC
Post by DeepSOIC »
Not surprisingly, Lattice Placement doesn't crash FreeCAD anymore! Thanks Eivind!!
Post by wmayer »
The funny thing is that when I comment out the assert it crashes in Debug build but according to DeepSOIC not in Release mode (I haven't tested it actually). However, in the past I read somewhere that it's allowed to invoke a method also of a null pointer or dangling pointer as long as you don't access any member variables inside this method. But I am not sure if this also applies to virtual methods.
Post by wmayer »
FYI, it crashes for me immediately in Release mode.
Post by wmayer »
