Arch Axis tool on a new document
Re: Arch Axis tool on a new document
Postby bernd » Wed Feb 10, 2016 3:35 pm
output if steps are done in FreeCAD GUI by Mous clicking
Python 2.7.8 (default, Nov 17 2014, 20:37:05) [MSC v.1800 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> import WebGui
>>> from StartPage import StartPage
>>> WebGui.openBrowserHTML(StartPage.handle(),App.getResourceDir() + 'Mod/Start/StartPage/','Start page')
>>> Gui.activateWorkbench("ArchWorkbench")
>>> App.newDocument("Unbenannt")
>>> App.setActiveDocument("Unbenannt")
>>> App.ActiveDocument=App.getDocument("Unbenannt")
>>> Gui.ActiveDocument=Gui.getDocument("Unbenannt")
>>> import Arch
>>> Arch.makeAxis()
>>> App.activeDocument().recompute()
bernd wrote:Be sure first change to arch wb and than create the new document !
Have you guys seen this !
jmaustpc
Postby jmaustpc » Wed Feb 10, 2016 3:37 pm
Yes, that is what I was doing.
Is there any chance that you guys have "DraftWB" disabled? There is, (or was, I can't see it just now) an option to hide the Draft WB as most of its tools were available in Arch.
Python 2.7.6 (default, Jun 22 2015, 18:01:27)
[GCC 4.8.2] on linux2
>>> import WebGui
>>> WebGui.openBrowserHTML(StartPage.handle(),'file://' + App.getResourceDir() + 'Mod/Start/StartPage/','Start page')
>>> App.newDocument("Unnamed")
>>> App.setActiveDocument("Unnamed")
>>> App.ActiveDocument=App.getDocument("Unnamed")
>>> Gui.ActiveDocument=Gui.getDocument("Unnamed")
>>> import Arch
>>> Arch.makeAxis()
>>> Gui.SendMsgToActiveView("ViewFit")
Postby bernd » Wed Feb 10, 2016 3:37 pm
Does this help:
- start FreeCAD
- copy the following code
import Arch
App.newDocument()
Arch.makeAxis()
gives error and axis is grey. There seams somthing with the view provider
>>> import WebGui
>>> import Arch
>>> App.newDocument()
<Document object at 00000000054960E0>
>>> Arch.makeAxis()
  File "C:\Daten\FreeCAD_0.16.6397_x64_dev_bin\Mod\Arch\ArchAxis.py", line 46, in makeAxis
    _ViewProviderAxis(obj.ViewObject)
  File "C:\Daten\FreeCAD_0.16.6397_x64_dev_bin\Mod\Arch\ArchAxis.py", line 141, in __init__
    vobj.Proxy = self
Base.FreeCADError: Unknown C++ exception
rockn
Postby rockn » Wed Feb 10, 2016 3:40 pm
Yes I follow exactly your steps.
Can you provide errors from Report View, please. If there is...
Formations et tutoriels FreeCAD en Français, soutenez moi : https://www.tipeee.com/formations-freecad
jmaustpc
Postby jmaustpc » Wed Feb 10, 2016 3:40 pm
yes,
but to be clear, I do not have to "recompute" a simple view zoom fit all shows them for me, and my recompute icon is greyed out.
jmaustpc
Postby jmaustpc » Wed Feb 10, 2016 3:42 pm
rockn wrote:Yes I follow exactly your steps.
none for me, but since it works for me of course you would expect that. the only message in my report view is of course "Arch workbench activated"
Postby bernd » Wed Feb 10, 2016 3:44 pm
rockn wrote:@bernd, I still can't reproduce.
No output in Report View ?
sorry rockn I missed the report view ... Ok here we are all informations ...
- startFreeCAD
- open Arch workbench
- create a empty document
- click on Arch axis tool
- click on recompute
- right click view fit
Python Konsole
>>> import WebGui
>>> import Arch
>>> Arch.makeAxis()
Report window:
Running the Python command 'Arch_Axis' failed:
  File "C:\Daten\FreeCAD_0.16.6397_x64_dev_bin\Mod\Arch\ArchAxis.py", line 75, in Activated
    FreeCADGui.doCommand("Arch.makeAxis()")
    vobj.Proxy = self
OS: Windows 7
Version: 0.16.6397 (Git)
Hash: 6763d3a6e48b6f74d48bca593baa8773897c7220
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
EDIT: or see Post viewtopic.php?f=23&t=14173&p=113740#p113735
Postby yorik » Wed Feb 10, 2016 5:51 pm
bernd wrote:Report window:
vobj.Proxy = self
Okay now we are advancing.. The view provider is not created, for some reason. I suspect it might have to do with the default settings. Can you try this code (with a new document open)? It should give more info:
o = App.ActiveDocument.addObject("App::FeaturePython","test")
import ArchAxis
ArchAxis._Axis(o)
ArchAxis._ViewProviderAxis(o.ViewObject)
o.Distances=[500,500]
o.Angles=[0,0]
Postby bernd » Wed Feb 10, 2016 6:03 pm
yorik wrote: Can you try this code (with a new document open)? It should give more info:
import ArchAxis
ArchAxis._Axis(o)
o.Angles=[0,0]
sure
- start FreeCAD
- make a new Document
>>> import ArchAxis
>>> ArchAxis._Axis(o)
<ArchAxis._Axis instance at 0x0000000009176B88>
    vobj.Proxy = self
TypeError: Property 'Distances': type in list must be float, not int
>>> o.Angles=[0,0]
TypeError: Property 'Angles': type in list must be float, not int
