This was done using two part cubes and two Draft Arrays. It can't get any simpler, and it's FAST. No sketching whatsoever. I'll also remind you guys that Expressions can be used to create formulas controlling dimensions of even primitives. This could be used in conjunction with the Spreadsheet Workbench.
But in my opinion people go to too much trouble attempting to build a fully parametric and automatically resizeable model. Sometimes it just bring unnecessary overhead. In the example above, granted, if I decide to change the size of the panels, I will have to change the array values and the placement of the parts. So what? I'd wager it will actually be a lot less time-consuming than trying to produce a complex model that can be automatically updated by changing a few dimensions in a spreadsheet. Or one that requires editing quite many sketches.
bejant wrote:Edit: You guys are posting so fast I can't keep up!
