Dark and Light FreeCAD stylesheets (v2.x merged to master)
triplus
Re: Dark and Light FreeCAD stylesheets (v2.x merged to master)
Postby triplus » Sun Mar 13, 2016 9:53 pm
Hi Pablo.
When you will feel like it and if you plan to do more work on Styling FreeCAD please open a thread in one of the mentioned forum sections. Something like Dark and Light FreeCAD stylesheets (v3.x WIP) ... We can therefore talk about it there.
As for the stylesheets merged into master it would be great if you would add that nicely styled check boxes to QListWidget items (QListWidgetItem) if possible. I noticed the ones in TabBar are done in system default style and after i checked where they could be found in FreeCAD. One example is Part WB -> Fillet tool. Select some edges to fillet and you can observe them.
Thanks.
triplus
Postby triplus » Sun Mar 13, 2016 10:19 pm
And actually the way i understand it you create feature and after it is merged in master you create feature announcements i this forum section.
Whatever discussion about this particular feature therefore should be done here in this forum section. Therefore Jim you need to elaborate more on this as i never heard you need to create feature announcements in this forum section and after open new thread in other forum section to talk about it. That after all is what this forum section is about.
Create feature -> merge master -> feature announcement topic opened -> discussion about the feature.
For a while i was actually convinced it isn’t appropriate to talk about this feature in this forum section. Go figure. ;)
pablogil
Postby pablogil » Mon Mar 14, 2016 7:43 am
Please, continue discussing bugs, feature requests, etc in this new thread under Development corner.
Thanks
