Symbols library
- Giovanni_Longo
Re: Symbols library
Thanks!
Re: Symbols library
Does this macro work anymore? Currently for v.21?
I couldn't figure out where I should edit it. I saw where this thread says to change the parameter but there doesn't seem to be one to change. If I try to run the macro, no window pops up nor does a dialog requesting the path.
Re: Symbols library
Nope, you need to change line 60 from:
folderDialog = QtGui.QFileDialog.getExistingDirectory(None,QtGui.QApplication.translate("SymbolsLibrary", "Location of your existing Symbols library", None, QtGui.QApplication.UnicodeUTF8)
folderDialog = QtGui.QFileDialog.getExistingDirectory(None,QtGui.QApplication.translate("SymbolsLibrary", "Location of your existing Symbols library", None, QtGui.QFileDialog.ShowDirsOnly))
- wandererfan
Re: Symbols library
I don't use this. Is there something I need to do?
There is a Symbol directory in the distribution (/home/wile/Target/FCDevl/share/Mod/TechDraw/Symbols on this machine). It looks to have more symbols than the Github repo.
Re: Symbols library
Personally I think it's redundant but maybe we get some users upgrading from 0.18.x who have developed their own libraries over time, in the 6 years I've used FC I've never known anyone use this, hence the surprise at the question today. Let's see what feedback there is but most likely nothing to do here.
Re: Symbols library
That other section of code doesn't fix it.
I needed it because the documentation on this topic is not very good. Even on the FreeCAD wiki, the only reference I found to a source for symbols is the workbench.
Re: Symbols library
The Techdraw workbench symbols are held in subfolders of (on Linux) src/share/Mod/TechDraw/Symbols (or on Windows) src\data\Mod\TechDraw\Symbols and if they are not welding, surface roughness then they are inserted through the general add symbol command https://wiki.freecad.org/TechDraw_Symbol , you need a Page to be created first obviously. If you find something is missing you can request for it to be added to the appropriate folder as applicable.charliemccraney wrote: ↑Sat Aug 19, 2023 4:54 am the only reference I found to a source for symbols is the workbench.
