Install FreeCAD-addons-master
MMSN
Post by MMSN »
Hi all,
FreeCad run excellent in my laptop as well as in my oldest IBM T20!
I starting to run script on the python console as area, volume, center of gravity and inertia without any inconvenient. Today I am trying install the macros FreeCad-addons-master where the file has been located in the address specified from the tutorial. The macros run and doesn't stop as show on the screenshot below.
What I have done wrong?
Thanks very much in advance.
OS: Windows Vista
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6704 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Re: Install FreeCAD-addons-master
Post by yorik »
I just checked, the macros works normally for me. Are you sure you have the latest version?
sgrogan
Post by sgrogan »
MMSN wrote: The macros run and doesn't stop as show on the screenshot below.
Try: Copy the addons-installer.FCMacro from "%appdata%/FreeCAD/FreeCAD-addons-master" to "%appdata%/FreeCAD%
It looks like the unzipped macro is one level too deep.
"fight the good fight"
MMSN
Post by MMSN »
Yorik,
Thanks very much for you response.
I think should be the latest one from this link:
https://github.com/FreeCAD/FreeCAD-addons (Download zip file to put in the C:\\Users\\myself\\AppData\Roaming\FreeCAD and doesn't stop of run as my previous e-mail.)
https://github.com/FreeCAD/FreeCAD-addo ... er.FCMacro( Directly to Phyton console.)
Here is the error message after paste the scrip into the phyton console:(Second option from tutorials)
May be I don't understand correctly the procedure.
Tanks again.
sgrogan
Post by sgrogan »
MMSN wrote:May be I don't understand correctly the procedure.
Maybe the instructions are not correct for windows. The addons-installer.FCMacro must be on the same level as the user.cfg and system.cfg files. Copy the contents of the FreeCAD-addons-master folder to the USERMAME/Appdata/Roaming/FreeCAD folder
MMSN
Post by MMSN »
sgrogan wrote:Maybe the instructions are not correct for windows. The addons-installer.FCMacro must be on the same level as the user.cfg and system.cfg files. Copy the contents of the FreeCAD-addons-master folder to the USERMAME/Appdata/Roaming/FreeCAD folder
sgrogan,
I have made this procedure as showed in the screenshot :FreeCAD-addons-master-3: USERNAME/appData/Roaming/FreeCad :)
Thank in advance yorik and sgrogan for your assistance.
MMSN
Post by MMSN »
sgrogan,
sgrogan
Post by sgrogan »
The file "macro-add-addons-installer.FCMacro" must be on this level not the folder "FreeCAD-addons-master"
Inside FreeCAD it should look like this
MMSN
Post by MMSN »
sgrogan wrote:The file "macro-add-addons-installer.FCMacro" must be on this level not the folder "FreeCAD-addons-master"
Yes as show in the screenshot FreeCAD-addons-master-1.It was running half hour and nothing..
Thanks
OS: Windows Vista
Qt version: 4.8.6
MMSN
Post by MMSN »
Estrange, I unzipped the folder FreeCAD-addons-master and open some sub folders and are empty.. Something wrong or is this normal?
