Doesn't appear the robotic workbench in my freeCAD v.014
steveendaniel
Post by steveendaniel »
Good afternoon for everybody, the robotic workbench doesn't appear in my freeCAD that mean .. "" /lib/FreeCAD/mod/ "" but in "" /lib/FreeCAD/lib/ "" in that file there are two files Robot.so and RobotGui.so and also in the "" lib/FreeCAD/data/mod/ "" there a file calle Robot with some archives inside, i don't know is these files have relation with the workbench please somebody know how the activate or install the robotic workbench..
Thank you.
DeepSOIC
Re: Doesn't appear the robotic workbench in my freeCAD v.014
Post by DeepSOIC »
Hi! Your post is rather hard to understand. + you are asking for support on an obsolete version of FC. So be prepared for people get annoyed :twisted: .
steveendaniel wrote:the robotic workbench doesn't appear in my freeCAD
Do you mean you don't have "Robot" workbench listed in workbench list? or does it fail to load?
Do you see any errors in Report View? (go to menu View->Views->Report View to activate it)
And please post complete version info, as instructed here.
quick61
Post by quick61 »
Thank you.
The easiest way to make sure everything is working as it should would be to get the latest release version of FreeCAD. You can find it from here - Download
FreeCAD 0.14 is several 3 years out of date! :shock:
Mark
Jee-Bee
Post by Jee-Bee »
quick61 wrote:FreeCAD 0.14 is several 3 years out of date! :shock:
i think 3 years old and 2 years out of date ;)
steveendaniel
Ok, is the first time for me to make question in a forum, for your comments i check my version is old, the newest version is the v0.16 i want learn about this software and also i'm new in linux ubuntu but is there some way to update my freecad because i was trying in the console terminal but i didn't have luck..... o uninstall this software and install again ... What happen with the folder on my hark disk?
Jee-Bee
Post by Jee-Bee »
I think you should remove first youre Freecad 0.14
after that type the following in you're terminal.
sudo add-apt-repository ppa:freecad-maintainers/freecad-stable
sudo apt-get update
when you have this done
sudo apt-get install freecad
should work
jmaustpc
Post by jmaustpc »
Or you could just read the forum rules link above which explains or links to explanations about exactly this and other important basic information.
