Wrong profile path (strange loops)
julienbld
Postby julienbld » Sat Sep 24, 2016 10:14 am
I draw a valid sketch containing lines and tangents arcs. I made a solid by extrusion and I tried to generate a profile path from this solid.
The result is not correct, there are some wrong "loops" in the path (where arcs join the lines)
Am I doing something wrong ? Is it a bug ? Is there a way to avoid this behaviour ?
Thank you !
bug.fcstd
(11.57 KiB) Downloaded 35 times
DeepSOIC
Re: Wrong profile path (strange loops)
Postby DeepSOIC » Sat Sep 24, 2016 11:03 am
Hi!
In the sketch, you have applied Tangent constraints the wrong way. You should do it using method 2, by selecting endpoints.
http://www.freecadweb.org/wiki/index.ph ... angency.29
You applied coincident constraint first, then tangent between edges. While that often works, it causes poor solver convergence, and consequently tangency mismatch. I believe this is the cause for the loops in path, but I think there might be another bug involved.
Unfortunately, I can't recompute your Path project in v0.17dev which I'm using.
File "C:\_vt\dev\PC\Qt\FreeCAD\Default\Mod\Path\PathScripts\PathProfile.py", line 275, in execute
self.vertFeed = toolLoad.VertFeed.Value
<type 'exceptions.AttributeError'>: 'FeaturePython' object has no attribute 'VertFeed'
Version: 0.17.8361 (Git)
Branch: DeepSOIC10
Hash: 4ac7673e543274bcae856872033a114c7b60481b
Python version: 2.7.8
OCC version: 7.0.0
julienbld
Postby julienbld » Sat Sep 24, 2016 11:27 am
Thank you !
It seems ok, now I can generate a valid path !
I don't understand why it was a problem for the solver, but this way is ok for me.
My version is 0.16. I think you can't compute the path because I didn't complete the horizontal and vertical speed fields. It might be mandatory in your version.
herbk
Postby herbk » Fri Oct 14, 2016 4:51 pm
i have the same Problem on some parts. It's not always, only if the parts a little more difficult.
Here's an example: i want to mill out this part:
and here the loops:
The loops are not on each pocket, the whole part has 34, the loops are only on this 2 pockets.
The differnt to julienbld's situation is: my part is made with the part and draft WB only, so there isn't any sketch.
magnetscheibe_34_magnete_mit_pfad.fcstd
(132.98 KiB) Downloaded 45 times
Gruß Herbert
mlampert
Postby mlampert » Fri Oct 14, 2016 6:10 pm
Hi Herbert,
Not on my computer right now, will check it out tonight. Which version are you using?
Markus
BTW: I had a quick look and you seem to have 4 of those issues, 2 on top and 2 at the bottom.
herbk
Postby herbk » Fri Oct 14, 2016 6:33 pm
Hi mlampert,
you are right, there two more on the bottom..
Im using
OS: "openSUSE 13.2 (Harlequin) (x86_64)"
Version: 0.17.8577 (Git) (Packman)
Hash: c833136cde65b90bdc2809c3022afdfa4a3a4bb6
Python version: 2.7.12
Qt version: 4.8.6
OCC version: 6.9.1.oce-0.18-dev
Its a 17.xx, but on opensuse are some functions not available...
Gruß Herbert
sliptonic
Postby sliptonic » Fri Oct 14, 2016 6:59 pm
herbk,
It looks like you're using OCC.
I tried it again with my current version that uses libarea by default and was able to get a normal looking path. However, libarea would often fail to generate a profile at all. I got it to work by playing with the 'extra offset' value, setting it to something like -0.01. It feels like a rounding bug but I'm not sure how to track it down.
Postby chrisb » Fri Oct 14, 2016 7:20 pm
It pretty sure is a rounding bug. Turning the cut before applying the path operation sometimes works, e.g. with 0.2°, and sometimes makes things even worse.
mlampert
Postby mlampert » Sat Oct 15, 2016 5:09 am
Hi Herbert,
Unfortunately I can't reproduce your issue (other than in your file) with any of the builds I have of 0.17
I did notice a few things:
* it works in the newer version (sliptonic has a pull request out - doesn't help you right now though)
* I got some good results by converting your magnet wheel to a "Solid" (Part menu) and build the path around that
* I can't create the outside path with other builds. I can create the "Right" path and the "On" path, but not the "Left" - which is not entirely true. After fixing some issues it does seem to build - except that there is no outcome.
Question to the experts: Is there a limit in the size or number of properties a Feature can have ?
Stab - stab - no, still dark .... sorry
herbk
Postby herbk » Sat Oct 15, 2016 5:36 am
sorry, double post...
Gruß Herbert
