I did not, I stopped work on lights because my experiments did not work like in the open inventor docs.
I use the calucation of the direction of the normal vector to compute the light intensity and cat put it as color map onto the (bspline) surface.
but for a good rendering FreeCAD is not best place. https://www.youtube.com/watch?v=AAnbG-HnIGM
Yes, most of your work is totally amazing to me Such studies however don't really require high quality renderings, more important is the quality of the results data (the numbers), when we talk about solar studies and such. But my post about the shadows was actually just to show that shadows are possible and as I understood Yoriks example, it is not a rendering but a "live" shadow directly in the 3d view?
saso wrote:[ But my post about the shadows was actually just to show that shadows are possible and as I understood Yoriks example it is not a rendering but a "live" shadow directly in the 3d view?
Yes, it should be according to open inventor theory, but I do not get it on my computer
By the way, in your work on point clouds did you look in to creating point clouds from pictures? There seem to be some quite usable open libraries but lacking of good and easy to use open tools (gui), http://ccwu.me/vsfm/ is for example best I could found, but with not the most open license... ?
when I have finished my version of the nurbs workbench (create models from point clouds)
I will continue my work on the reconstruction workbench and improve pattern recognition
to get geometrical objects (lines, circles, planes, spheres etc.) from images
for calculating 3D information from multiple images there are already good algorithms
I will remember your link and look how to reuse it, thank you
Point clouds have generally be done with laser scans, lasers however are expensive so people have come up with this technique (https://en.wikipedia.org/wiki/Photogrammetry) to create point clouds (also big and dense ones) from images. VisualSFM as I understand is more just a gui for some of the open libraries for doing this... Here is one video how to set it up and use it with some nice example of scanning terrain with a drone https://www.youtube.com/watch?v=wBKidr0e-XA There are of course also comercial solutions for this like for example Autodesk ReCap https://www.youtube.com/watch?v=5lQVH3hSh0c
The example from the other post was just to show that coin can do it. But indeed there are several problems, I could never make it work on the Intel, only on the Nvidia chip.
In any case, it requires encapsulating he whole scene in a SoShadowGroup node. Which cannot currently be done in python. So we need to modify the FreeCAD 3D view to add space for that node. Then with pivy we can tweak it as it needs. But didn't look much at how to do that yet
it's still a dream for me,
I use a kinect sensor to get 3d data. this is good enough for the moment and easy to use.
the software to use it is open source
for working with 2d images there are some methods in opencv too
yorik wrote:The example from the other post was just to show that coin can do it. But indeed there are several problems, I could never make it work on the Intel, only on the Nvidia chip.
Do you maybe know if it is just the older Intel chips, they are quite well known to have bad support for graphic stuff? If that is the only issue I would say it should not represent a reason not to implement it, shadows would be nice to have, even if just "false" shadows (unreal sun direction). Any info for AMD chips? I will try to find some time to test this a bit more, if I will know how to
