Macro for BIM simulation of work
microelly2
Re: Macro for BIM simulation of work
Postby microelly2 » Thu Nov 24, 2016 10:20 am
I see a first real application of cascaded Animation managers: Every activity can be mapped to a manager which controls some animation nodes
what still is needed: create a DAG with managers from the project database.
once more a 2d node editor like pse ore sverchok makes sense.
walpa
Postby walpa » Thu Nov 24, 2016 11:59 am
chakkree wrote:Your code can run with python 2.7
But change line 102 to
Msg ("id:%s transparency: %d\n" %(o, p ))
Thanks for the sugestion.
What I am not understanding are the different results for the value of transparency.
walpa
Postby walpa » Thu Nov 24, 2016 1:20 pm
yorik wrote:Yes that's a good idea... The thing is how to do that the clever way. There are a lot of standards to represent time ( https://en.wikipedia.org/wiki/Timestamp ) but a simple integer can be used to store a time stamp.
also, we might need something different than just timestamps, more like time spans. So this could evolve into something bigger, where your objects "belong" to a certain phase, etc...
I'm a beginner ... getting lost and learning ...
I think the gantt.py (viewtopic.php?t=15865) code could be used as the basis for a built-in FRC planner. datetime.date was used, but if another type is better, I accept guidance.
saso wrote:First thing to check would IMO be to check if maybe IFC has support for this?
yorik wrote:I think it has, don't remember exactly what, but I've seen something about construction phases in the docs.
I do not even know where to start ... :)
yorik wrote:In any case this all goes into the same direction: We should look at what/how others do and build a plan...
But I think:
First stage (I'm developing):
Create object with file information: path, name, ...
Create sub-objects with task information
Linking obj FRC (property) to tasks
Do basic animation (transparency)
To appear in the FRC interface
Second stage:
Cascaded Animation managers (microelly2 help us)
Third stage:
(gantt.py)
Create interface to view the gantt in FRC
Create interface to manipulate gantt data, and export file
Fourth stage:
a dream...
Artificial intelligence: collision of objects, critical path of the work, cost as a function of time ...
yorik wrote:Maybe the construction phase needs to be like a material? An external object?
I think external object can give more freedom to designer linking obj FRC to tasks you want, but I still do not know FRC like you guys to say that.
Is it possible to create a property for objectgroup? It would be a way to create construction phase.
chakkree
Postby chakkree » Thu Nov 24, 2016 1:53 pm
I think int/int = 0
casting integer variable to float.
change to
self.percentConclTask = int((1-( float(concl) / totalDays))*100)
import xml.etree.ElementTree as ET
from datetime import datetime,  date
from PySide import QtCore, QtGui
class PlannerData:
    def __init__(self, file):
        self.file = file
        self.taskData = {}
        self.startDate = None
        self.finishDate = None
        self.projPeriod = None
        self.seqDays = []
        self.percentConclTask = None
    def getXmlData(self):
        "gets data in the document ProjectLibre xml"
        tree = ET.parse(self.file)
        root = tree.getroot()
        #gets data of the tasks
        task = root.findall("{http://schemas.microsoft.com/project}Tasks")
        for parent in task:
            for child in parent:
                a=[]
                uid = child.findtext("{http://schemas.microsoft.com/project}UID")
                name = child.findtext("{http://schemas.microsoft.com/project}Name")
                start = child.findtext("{http://schemas.microsoft.com/project}Start")
                start = datetime.strptime(start, '%Y-%m-%dT%H:%M:%S').date()
                finish = child.findtext("{http://schemas.microsoft.com/project}Finish")
                finish = datetime.strptime(finish, '%Y-%m-%dT%H:%M:%S').date()
                period = finish-start
                period = period.days
                #list of data of task
                a.append(uid)
                a.append(name)
                a.append(start)
                a.append(finish)
                a.append(period)
                self.taskData[uid] = a
        #gets data of the project period
        start2 = root.findtext("{http://schemas.microsoft.com/project}StartDate")
        self.startDate = datetime.strptime(start2, '%Y-%m-%dT%H:%M:%S').date()
        finish2 = root.findtext("{http://schemas.microsoft.com/project}FinishDate")
        self.finishDate = datetime.strptime(finish2, '%Y-%m-%dT%H:%M:%S').date()
        period = self.finishDate - self.startDate
        self.projPeriod = period.days
        #gets the sequence of days between the start and end date of the project for use in Simulation
        dat = self.startDate
        while dat <= self.finishDate:
            self.seqDays.append(dat)
            dat = date.toordinal(dat)+1
            dat = date.fromordinal(dat)
        return    self.taskData#, self.startDate, self.finishDate#,  self.projPeriod, self.seqDays
    def getCsvData(self):
        "gets data in the document Csv"
        pass
    def calcPercentConclTask(self, task,  dat):
        "calculation of the percentage of completion of the task for use in the visualization of the Simulation"
        #Msg(self.taskData); Msg('\n\n')
        tasks = self.taskData
        start = tasks[task][2]
        finish = tasks[task][3]
        totalDays = tasks[task][4]
        """Msg(task); Msg(' ')
        Msg(dat ); Msg(' ')
        Msg(start); Msg(' ')
        Msg(finish);  Msg('\n')
        Msg(dat < start);Msg(dat > finish); Msg(' ')"""
        if dat < start:
            self.percentConclTask = 100
        elif dat > finish:
            self.percentConclTask = 0
        else:
            concl = dat-start
            concl= concl.days
        #Msg('%g\n'%self.percentConclTask)
        return self.percentConclTask
def execute():
    #for teste in FreeCad
    filename = QtGui.QFileDialog.getOpenFileName(QtGui.qApp.activeWindow(),'Open file','*.xml')
    file =filename[0]
    #for test in IDLE Python, copy file to the same directory
    #file  = 'teste1.xml'
    teste='2016-11-28T08:00:00'
    dat = datetime.strptime(teste, '%Y-%m-%dT%H:%M:%S').date()
    Msg (dat); Msg('\n')
    plan = PlannerData(str(file))
    i = plan.getXmlData()
    Msg (i); Msg('\n')
    for o in i:
        start=i[o][2]
        finish=i[o][3]
        totalDays=i[o][4]
        p= plan.calcPercentConclTask( o,  dat)
        Msg ("id:%s %s transparency: %d\n" %(o, i[o][1], p ))
execute()
saso
Postby saso » Thu Nov 24, 2016 2:21 pm
As I understand the problems is that the transparency values should be 0 (fully visible, as construction finished), 50, 100, 100, 100 (invisible, as construction not yet started) and not 0, 22, 28, 100, 100 ?
walpa
Postby walpa » Fri Nov 25, 2016 11:38 am
@ chakkree
Thank you, problem solved.
saso wrote:As I understand the problems is that the transparency values should be 0 (fully visible, as construction finished), 50, 100, 100, 100 (invisible, as construction not yet started) and not 0, 22, 28, 100, 100 ?
All objects start with 100 (invisible), and the transparency value decreases in proportion to the date's progress until they are visible.
saso
Postby saso » Fri Nov 25, 2016 3:42 pm
Yes, I understood wrongly what the problem with your code was...
walpa
Postby walpa » Thu Dec 01, 2016 10:07 pm
I ask for help again.
I was able to make a macro that worked as I wanted it :D
So I ventured to develop a workbench to make life easier ...
It is working until the initialization of a GUI for the user to search the data source file (XML), then it gives error:
"Gui :: Command :: activated (0): Unknown C ++ exception thrown"
frc erro.jpg (70.69 KiB) Viewed 1269 times
Probably some stupidity from line 55 of the Planner.py file.
Any idea?
Thanks.
Walmir
Follow the files ...
Project_test.FCStd
(38.28 KiB) Downloaded 30 times
Planner.zip
(18.25 KiB) Downloaded 25 times
Project_test.zip
(3.05 KiB) Downloaded 30 times
walpa
Postby walpa » Tue Dec 06, 2016 6:38 pm
Problem solved.
The import QTdesigner UI file was the error.
walpa
Postby walpa » Tue Dec 06, 2016 8:00 pm
Available the first prototype of the workbench planner, for anyone who has an interest in testing.
Tutorial:
- creating objects on Arch workbench
- access Planner workbench
- click to Create Planner
- search xml file
- click import data and close
- on each Arch object, set the Planner_ID property, linking to the activity
- select the Planner group and click Create Simulation
The result (in my opinion) still does not have a good effect, but it is only a first experience. If a more complex animation is applied, it can be interesting.
I expect criticism and suggestions.
Thanks.
Walmir
Ps - sorry for the screens in portuguese
Planner.zip
(18.93 KiB) Downloaded 40 times
