Trouble with spreadsheet
psolyca
Postby psolyca » Wed Jan 04, 2017 9:41 pm
Hello,
I am using FreeCAD actively for 2-3 months.
I tried the 0.16 version but I had some missing functions so I use the 0.17 :
OS: Windows 8.1
Version: 0.17.9467 (Git)
Hash: 40ad0b743aabad9e415b921bac9312e34735e0a8
Python version: 2.7.8
OCC version: 7.0.0
The step-by-step procedure :
  • Create a spreadsheet
  • Enter some text, parameters and alias - for example text (A1) : Radius, parameter (B1) : 10, alias (B1) : R
  • Create a body
  • Create an empty sketch
  • Go back to the spreadsheet, select a text -> you can not erase your text
  • Close and reopen the spreadsheet (or force recompute of spreadsheet), select your text -> you can erase your text
  • Draw something on your sketch - for example a circle
  • Go back to the spreadsheet, select a text -> you can not erase your text and sometimes the sketch is deleted
  • Go back to your sketch, use a parameter from your spreadsheet - an expression for a radius constraint on the circle : Spreadsheet.R
  • Close and reopen the spreadsheet (or force recompute of spreadsheet), select a text not the parameter -> error message "The following, referencing objects might break. Are you sure you want to continue ? Sketch"
The same message appear if I try to delete the spreadsheet.
I do not have error message in the report view nor in the python console.
It is behaving like the text is not activated when selected but the spreadsheet.
Am I doing something wrong or is it a bug ?
DeepSOIC
Re: Trouble with spreadsheet
Postby DeepSOIC » Wed Jan 04, 2017 10:30 pm
psolyca wrote:is it a bug ?
Yep, I can reproduce, with one correction:
it reproduces if I select a CELL and press delete key. It may delete the last sketch instead of clearing the cell.
If I select the actual TEXT, by double-clicking the cell so that I see the blinking cursor, I can delete the text by pressing delete or backspace key.
I would like to add, that if I load Draft workbench, I can't type certain stuff into spreadsheet without double-clicking the cell first. For example, if I select a cell, and type "ellipse", Draft Ellipse command is activated, and only "lipse" ends up in the cell. Annoying as hell!
psolyca
Postby psolyca » Thu Jan 05, 2017 12:55 pm
Yes, i tried that after I post the message.
So it means that the spreadsheet is not activated even if a cell inside is selected !
Do I open an issue in the tracker ?
eivindkvedalen
Postby eivindkvedalen » Thu Jan 05, 2017 1:30 pm
psolyca wrote:Yes, i tried that after I post the message.
I'm unable to recreate this problem here on Ubuntu. Could this be an issue on Windows only?
Eivind
salp
Postby salp » Fri Jan 06, 2017 12:54 am
OS: Linux Mint 18 Sarah
Version: 0.17.9507 (Git)
Build type: None
Hash: 608f7371700b2dff74279ca53239d27f61fdb699
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
I can recreate the issue, only if I edit the spreadsheet first.
Actually once I edit the spreadsheet, It wont let me add a Sketch to a Body, with the error that I need to select a body first.
When I double click on the Body or right click and select "Toggle Body" from the pop up menu, the body does not get activated.
The above scenario happens if the Spreadsheet window is still open.
The report view give the following output:
Unhandled Base::Exception caught in GUIApplication::notify.
The error message is: 'NoneType' object has no attribute 'setActiveObject'
The event type 3 was sent to QMenu
Object tree:
QMenu
eivindkvedalen
Postby eivindkvedalen » Fri Jan 06, 2017 5:01 pm
I can recreate this now. It seems that if the selected node in the treeview is not the spreadsheet, the delete key goes to the wrong viewprovider, and thus some other object is deleted.
DeepSOIC wrote: I would like to add, that if I load Draft workbench, I can't type certain stuff into spreadsheet without double-clicking the cell first. For example, if I select a cell, and type "ellipse", Draft Ellipse command is activated, and only "lipse" ends up in the cell. Annoying as hell!
Seems to be related, i.e the keyboard events are sent to the wrong viewprovider, although I haven't looked into the details here.
Eivind
psolyca
Postby psolyca » Sat Jan 07, 2017 3:33 pm
After lots of tries, I manage to build the same version for my Debian.
OS: Debian GNU/Linux testing (stretch)
Build type: Debug
Branch: (HEAD détachée sur 40ad0b743)
Python version: 2.7.13
And I have the same issue even if I create first the body, then the sketch and finally the spreadsheet.
An other think not really related is the behavior of the ENTER event between Windows and Linux.
In Linux, when I fill a cell and press ENTER, the selection move to the next cell.
In Windows, when I fill a cell and press ENTER, the selection do not move.
eivindkvedalen
Postby eivindkvedalen » Sat Jan 07, 2017 7:45 pm
psolyca wrote: Do I open an issue in the tracker ?
Yes, please do. Add steps to recreate the problem in tracker, and also a reference to this thread would be good to have.
Eivind
Postby Kunda1 » Fri Nov 10, 2017 4:39 pm
Eivind
Linking issue #2833 to this thread.
Postby wmayer » Wed Sep 12, 2018 3:48 pm
