contact constraint example
Post by bernd »
I downloaded the contact constraint example from here: viewtopic.php?t=16749#p132166 applied a new material Calculix-Steel and a new Solver calculix. But ccx breaks with some error. May be I use the wrong iteration parameter ... The FreeCAD file is attached.
FemTools.setup_working_dir()  -->  self.working_dir = /tmp/FEMWB/
FemInputWriterCcx --> self.dir_name  -->  /tmp/FEMWB/
FemInputWriterCcx --> self.main_file_name  -->  Fusion_Mesh.inp
FemInputWriterCcx --> self.file_name  -->  /tmp/FEMWB//Fusion_Mesh.inp
('  ReferenceShape : ', 'Face', ', ', 'Fusion', ', ', u'Fusion', ' --> ', 'Face5')
('  ReferenceShape : ', 'Face', ', ', 'Fusion', ', ', u'Fusion', ' --> ', 'Face8')
('  ReferenceShape : ', 'Face', ', ', 'Fusion', ', ', u'Fusion', ' --> ', 'Face6')
('  ReferenceShape : ', 'Face', ', ', 'Fusion', ', ', u'Fusion', ' --> ', 'Face10')
len femnodes_ele_table:2983
('  ReferenceShape : ', 'Face', ', ', 'Fusion', ', ', u'Fusion', ' --> ', 'Face9')
len node_set: 577
len bit_pattern_dict:1316
('found Faces: ', 252)
('faces: ', [[1322, 2], [1516, 1], [1701, 1], [1727, 1], [1728, 1], [1729, 1], [1733, 3], [1745, 2], [1746, 3], [1751, 3], [1754, 2], [1756, 1], [1757, 4], [1759, 4], [1761, 1], [1762, 1], [1763, 2], [1765, 1], [1773, 2], [1775, 1], [1778, 2], [1779, 2], [1781, 1], [1782, 4], [1786, 3], [1803, 2], [1804, 2], [1805, 2], [1806, 4], [1807, 2], [1809, 3], [1810, 4], [1812, 4], [1813, 3], [1815, 1], [1817, 2], [1821, 4], [1824, 3], [1825, 3], [1826, 2], [1828, 4], [1830, 2], [1834, 1], [1836, 2], [1839, 1], [1840, 3], [1842, 1], [1846, 2], [1847, 4], [1848, 2], [1852, 4], [1854, 1], [1866, 4], [1869, 4], [1875, 3], [1881, 2], [1882, 1], [1883, 2], [1885, 3], [1886, 3], [1888, 3], [1895, 1], [1896, 2], [1897, 2], [1902, 2], [1905, 1], [1914, 2], [1921, 4], [1933, 2], [1935, 2], [1940, 3], [1941, 2], [1946, 1], [1947, 3], [1953, 1], [1958, 3], [1961, 3], [1966, 2], [1976, 3], [1983, 2], [1989, 2], [1993, 1], [1994, 4], [1996, 4], [1998, 2], [2001, 2], [2008, 1], [2010, 3], [2018, 4], [2024, 1], [2030, 4], [2031, 4], [2042, 3], [2044, 1], [2046, 4], [2047, 2], [2056, 4], [2057, 2], [2071, 1], [2075, 1], [2076, 4], [2079, 3], [2080, 1], [2081, 1], [2082, 2], [2083, 3], [2088, 1], [2089, 2], [2090, 2], [2091, 2], [2093, 2], [2107, 3], [2108, 2], [2116, 4], [2119, 4], [2122, 1], [2125, 3], [2128, 4], [2135, 1], [2136, 3], [2140, 3], [2141, 4], [2146, 1], [2147, 2], [2151, 3], [2152, 4], [2154, 4], [2155, 3], [2156, 3], [2160, 3], [2164, 3], [2166, 4], [2167, 1], [2168, 2], [2169, 3], [2171, 2], [2172, 1], [2174, 4], [2176, 2], [2179, 4], [2183, 1], [2189, 3], [2191, 1], [2192, 4], [2197, 3], [2198, 3], [2200, 1], [2204, 2], [2206, 2], [2211, 3], [2216, 2], [2218, 3], [2220, 2], [2222, 4], [2228, 4], [2229, 1], [2231, 1], [2235, 2], [2238, 4], [2241, 2], [2246, 1], [2247, 2], [2250, 1], [2251, 2], [2259, 2], [2262, 2], [2264, 3], [2266, 4], [2268, 4], [2269, 2], [2272, 4], [2273, 4], [2276, 3], [2278, 4], [2279, 1], [2286, 1], [2290, 3], [2292, 3], [2296, 3], [2307, 3], [2310, 4], [2312, 3], [2314, 1], [2318, 1], [2321, 3], [2323, 2], [2325, 4], [2327, 1], [2336, 4], [2344, 2], [2346, 4], [2347, 3], [2349, 2], [2355, 2], [2358, 3], [2361, 2], [2363, 4], [2369, 3], [2372, 2], [2380, 4], [2390, 1], [2392, 4], [2396, 4], [2397, 4], [2400, 3], [2404, 3], [2406, 2], [2408, 3], [2425, 1], [2430, 2], [2436, 2], [2439, 2], [2442, 3], [2451, 1], [2452, 3], [2462, 1], [2464, 1], [2472, 1], [2477, 4], [2478, 1], [2482, 3], [2488, 3], [2491, 1], [2493, 1], [2496, 2], [2499, 1], [2505, 3], [2512, 2], [2514, 3], [2521, 1], [2526, 4], [2530, 1], [2534, 2], [2536, 3], [2537, 4], [2542, 1], [2546, 2], [2548, 4], [2550, 3], [2552, 4], [2556, 3], [2557, 2], [2559, 2], [2560, 2], [2570, 1], [2580, 2], [2584, 2], [2585, 1], [2586, 1], [2589, 1], [2592, 3], [2596, 2]])
Writing time input file: 0.657094
Analysis failed with exit code 201
--------start of stderr-------
--------end of stderr---------
--------start of stdout-------
CalculiX Version 2.11, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on So 31. Jul 13:26:31 CEST 2016
  The numbers below are estimated upper bounds
  number of:
   nodes:         2983
   elements:         2596
   one-dimensional elements:            0
   two-dimensional elements:            0
   integration points per element:            4
   degrees of freedom per node:            3
   layers per element:            1
   distributed facial loads:          252
   distributed volumetric loads:            0
   concentrated loads:            0
   single point constraints:          312
   multiple point constraints:            1
   terms in all multiple point constraints:            1
   tie constraints:            1
   dependent nodes tied by cyclic constraints:            0
   dependent nodes in pre-tension constraints:            0
   sets:            6
   terms in all sets:         9304
   materials:            2
   constants per material and temperature:            4
   temperature points per material:            1
   plastic data points per material:            0
   orientations:            0
   amplitudes:            2
   data points in all amplitudes:            2
   print requests:            2
   transformations:            0
   property cards:            0
 *INFO: time control parameters set to:
        i0 =            4
        ir =            8
        ip =            9
        ic =          200
        il =           10
        ig =          400
        is =            0
        ia =          200
        ij =            0
        it =            0
        df =   0.25000000000000000
        dc =   0.50000000000000000
        db =   0.75000000000000000
        da =   0.84999999999999998
        ds =    0.0000000000000000
        dh =    0.0000000000000000
        dd =    1.5000000000000000
        wg =    0.0000000000000000
 STEP            1
 Static analysis was selected
 Newton-Raphson iterative procedure is active
 Decascading the MPC's
 Determining the structure of the matrix:
 number of equations
 8637
 number of nonzero lower triangular matrix elements
 269628
 increment 1 attempt 1
 increment size= 1.000000e-01
 sum of previous increments=0.000000e+00
 actual step time=1.000000e-01
 actual total time=1.000000e-01
 iteration 1
 Number of contact spring elements=0
 number of equations
 8637
 269628
 Using up to 2 cpu(s) for the stress calculation.
 Using up to 2 cpu(s) for the symmetric stiffness/mass contributions.
 Factoring the system of equations using the symmetric spooles solver
 Using up to 2 cpu(s) for spooles.
 average force= 2095.935420
 time avg. forc= 2095.935420
 largest residual force= 0.000000 in node 2899 and dof 2
 largest increment of disp= 5.586546e+00
 largest correction to disp= 5.586546e+00 in node 1738 and dof 2
 no convergence
 iteration 2
 number of equations
 8637
 269628
 largest residual force= 0.000000 in node 2903 and dof 2
 largest correction to disp= 3.813563e-12 in node 709 and dof 2
 convergence
 Using up t
--------end of stdout---------
CalculiX failed ccx finished with error 201
OS: Debian GNU/Linux 8.7 (jessie)
Version: 0.17.9803 (Git)
Build type: Unknown
Hash: dd63fe92107a87f6003f33518e387743a2090a1c
Python version: 2.7.9
Qt version: 4.8.6
OCC version: 7.0.0
contact-example-udated.fcstd
(356.43 KiB) Downloaded 124 times
fandaL
Re: contact constraint example
Post by fandaL »
With your file I get results. I didn't change any parameter.
OS: Windows 7
Version: 0.17.9822 (Git)
Hash: 0df4af4ba5e6edce825af6ecf6d024c704292633
Python version: 2.7.8
OCC version: 7.0.0
Post by bernd »
fandaL wrote:
bernd wrote:contact-example-udated.fcstd
I get resuts too, but they are different from the ones included in the file. These are the original results.
fandaL
Post by fandaL »
Original absolute displacement:
29,7740 mm
After recomputing (in the last result object "CalculiX_static_time_0_0_results009"):
29.7562 mm
bernd wrote:...new material Calculix-Steel...
There is "Steel-Generic" with E = 200 000 MPa, I didn't change it.
Post by bernd »
fandaL wrote:Original absolute displacement:
29,7740 mm
29.7562 mm
which version of ccx do you use?
Post by bernd »
would you post your *.inp file?
fandaL
Post by fandaL »
same results with ccx 2.11 and ccx 2.8p2
Fusion_Mesh.inp.txt
(178.35 KiB) Downloaded 109 times
Post by bernd »
fandaL wrote:same results with ccx 2.11 and ccx 2.8p2
Fusion_Mesh.inp.txt
It's crazy, if I run the file on linux with 2.11 it breaks after second time step, if I run the file on windows with 2.10 I get the same results as you. I get 10 results and the last one has max deformation 29.76 mm, really strange.
could one of other linux guys test if the file runs ? I'd be curious if it only breaks for me or if it breaks for all linux binaries.
cheers bernd
Post by bernd »
OS: Windows 7
OCC version: 7.0.0
same for me on Windows ... and the old ccx 2.8.2 which is included in FreeCAD
OS: Windows 7
OCC version: 7.0.0
Thanks fandaL for testing.
makkemal
Post by makkemal »
I don't have a problem this model runs.
ccx 2.10
OS: Ubuntu 16.04.1 LTS
Version: 0.17.9820 +11 (Git)
Build type: Unknown
Branch: Beam3Doutput
Hash: fe6786daa60732912946ee09d347f435a9505ca8
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
contact_example.fcstd
(292.37 KiB) Downloaded 152 times
