Quad Mesh
microelly2
Quad Mesh
Postby microelly2 » Mon Jan 30, 2017 8:26 am
At the moment I see only a small number of methods in the mesh wb,
I need more power to handle large data sets without render functionality.
Are there already fast methods available in FreeCAD from Python to create quad meshes from triangulated meshes?
what of the methods described in
Quad-Mesh Generation and Processing: a survey
David Bommes 1, Bruno Lévy 2, Nico Pietroni 3, Enrico Puppo 4, Claudio Silva 5;7, Marco Tarini 6, Denis Zorin 7
are ready to use in the current FreeCAD?
thanks for some tipps that can show me the direction to go.
EDIT: Example from maya
looo
Re: Quad Mesh
Postby looo » Mon Jan 30, 2017 12:39 pm
gmsh has implemented some algorithms: http://gmsh.info/doc/preprints/gmsh_quad_preprint.pdf
microelly2
Re: Quad Mesh
Postby microelly2 » Mon Jan 30, 2017 1:01 pm
looo wrote:gmsh has implemented some algorithms: http://gmsh.info/doc/preprints/gmsh_quad_preprint.pdf
thank you for that link.
HoWil
Re: Quad Mesh
Postby HoWil » Mon Jan 30, 2017 8:31 pm
Hi Microelly2,
Are you "only" interested in 2D-meshing or could this be extended to 3D?
If so maybe you could contribute your work to FEM-wb.
BR,
HoWil
microelly2
Re: Quad Mesh
Postby microelly2 » Mon Jan 30, 2017 9:55 pm
HoWil wrote:Hi Microelly2,
BR,
HoWil
I look for a way to get CAD model from non CAD data sources: 2D Images and 3D scanned point clouds. So nurbs, quadmeshes, Voronoi, Delaunay, voxels are on my way. I think there will be useful ideas for 3D segmentations too. At the moment I do a lot of performance tests on large datasets to see how to handle them inside FreeCAD in short time.
My solution of quad mehs for today is a scipy Rbf Interolation. Meantime I get good results for linear, cubic and thin plate interpolation.
https://www.youtube.com/watch?v=6ly86bF0sUc
Re: Quad Mesh
Postby bernd » Tue Jan 31, 2017 7:08 am
+1 I have been trying to make quad and hexa meshes with GMSH many times but failed ...
@microelly2:
FreeCAD 0.17 FEM has a GMSH mesh object and the mesh algorithm can be adjusted. New parameter could be added easily. But as I wrote I failed to make a hexa mesh.
fandaL
Re: Quad Mesh
Postby fandaL » Tue Jan 31, 2017 12:29 pm
hmmm, attractive topic...
@microelly2:
Did you failed to create any quad mesh?
Surprisingly it is not (only) about setting meshing algorithm but it seems that quads are created from triangles by option "Recombine all triangular meshes" which you find in gmsh at Tools/Options/Mesh/General. If you trigger this option, gmsh generates quads. Try also to change "Blossom" to "Standard" which influences quads.
The parameters are mentioned in 11th example http://gmsh.info/doc/texinfo/#t11_002egeo as
// To generate quadrangles instead of triangles, we can simply add
Recombine Surface{100};
I tried to add this into (nowadays yet) old GMSH macro "Custom gmsh options" line but without any influence.
There is also
// If we'd had several surfaces, we could have used 'Recombine Surface "*";'.
// Yet another way would be to specify the global option "Mesh.RecombineAll =
// 1;".
I have not much clue how exactly GMSH interacts with FreeCAD, but global option is yet coded in FemGmshTools.py
https://github.com/FreeCAD/FreeCAD/blob ... #L358-L361
After ommiting if condition (only to test if it does something)
#if hasattr(self.mesh_obj, 'RecombineAll') and self.mesh_obj.RecombineAll is True:
geo.write("//recombine\n")
geo.write("Mesh.RecombineAll = 1;\n")
geo.write("\n")
FreeCAD generates quad meshes on surfaces ;) except that makes mess on volumes...
Re: Quad Mesh
Postby bernd » Tue Jan 31, 2017 4:45 pm
Quad surface meshes could be made with FreeCAD FEM GMSH mesh. Just activate the recombine in Property editor change to 2D mesh.
fandaL wrote:FreeCAD generates quad meshes on surfaces ;) except that makes mess on volumes...
Thats exact the problem. I have not been able to make a valid hex mesh
