I entcounter a problem regarding a eigenfrequency simulation with calculix in FC.
I have the following model and can run a static simulation but when switching to frequency-analysis I see the following error messages:
Active analysis found: Analysis
We gone start GMSH FEM mesh run!
Part to mesh: Name --> Extrude, Label --> Extrude, ShapeType --> Solid
CharacteristicLengthMax: 1e+22
CharacteristicLengthMin: 0.0
ElementOrder: 2
ElementDimension: 3
/tmp/Extrude_Geometry.brep
/tmp/Extrude_Mesh_TmpGmsh.unv
/tmp/shape2mesh.geo
gmsh
No mesh group objects.
Group meshing.
No mesh regions.
Start: ViewProviderFEMMeshBuilder::createMesh() =================================
0.001000: Start build up 13940 face helper
0.029000: Start eliminate internal faces SIMPLE
1.199000: Start build up node map
1.210000: Start set point vector
1.213000: Start count triangle size
NumTriangles:10776
1.213000: Start build up triangle vector
1.273000: Start build up edge vector
NumEdges:16164
1.281000: Finish =========================================================
The Part should have a pretty new FEM mesh!
ThermalConductivity not found in material data of: None
ThermalExpansionCoefficient not found in material data of: None
SpecificHeat not found in material data of: None
FEM preferences working dir is not set, the solver working directory is used.
Dir '' doesn't exist and cannot be created.
Dir '/tmp' will be used instead.
FemTools.setup_working_dir() --> self.working_dir = /tmp
FemInputWriterCcx --> self.dir_name --> /tmp
FemInputWriterCcx --> self.main_file_name --> Extrude_Mesh.inp
FemInputWriterCcx --> self.file_name --> /tmp/Extrude_Mesh.inp
(' ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face1')
(' ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face2')
(' ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face3')
(' ReferenceShape : ', 'Face', ', ', 'Extrude', ', ', u'Extrude', ' --> ', 'Face4')
Writing time input file: 0.327914
Invalid Signal signature: textchanged()
Writing time input file: 0.452673
Analysis failed with exit code 201
--------start of stderr-------
--------end of stderr---------
--------start of stdout-------
CalculiX Version 2.9, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Thu Jan 21 05:18:00 UTC 2016
The numbers below are estimated upper bounds
number of:
nodes: 7532
elements: 6543
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 4
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 0
single point constraints: 3264
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 4
terms in all sets: 23122
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 1
data points in all amplitudes: 1
print requests: 2
transformations: 0
property cards: 0
STEP 1
Frequency analysis was selected
Decascading the MPC's
Determining the structure of the matrix:
number of equations
19332
number of nonzero lower triangular matrix elements
603945
Using up to 4 cpu(s) for the stress calculation.
*ERROR in e_c3d: nonpositive jacobian
determinant in element 6195
determinant in element 6196
determinant in element 6205
--------end of stdout---------
CalculiX failed ccx finished with error 201
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemSolverCalculix
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMeshGmsh
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMaterial
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _FemMechanicalResult
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemSolverCalculix
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMaterial
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMeshGmsh
0.000000: Start build up 2016 face helper
0.004000: Start eliminate internal faces SIMPLE
0.019000: Start build up node map
0.020000: Start set point vector
0.021000: Start count triangle size
NumTriangles:1760
0.021000: Start build up triangle vector
0.026000: Start build up edge vector
NumEdges:2640
0.026000: Finish =========================================================
<unknown exception traceback><type 'exceptions.ImportError'>: No module named _ViewProviderFemMechanicalResult
NumTriangles:1760
NumEdges:2640
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10412 (Git)
Build type: Unknown
Branch: femdev
Hash: 9229026ea3348cfa6eec93d1e7086359b5f6a508
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
also tried/rebuilt it on and a two days old master version, did rebuild it several times because FC-material did change a lot:
Version: 0.17.10168 (Git)
Build type: None
Hash: 6630bcf9fa8e849fe846d1c2b780148a7a2c1e4b
Here the simpler but working model: I do not know why it is working with the simpler geometry and appreciate any hints and help.
Thanks in advance,
HoWil
