Specific complaint: Sketcher is not rotating the drawing to make a line horizontal.
The problem is repeatable and how-to-reproduce is given in the attachment Sketcher_hides_gridlines_ap7b.pdf.
Thanks for considering this issue.
(Apologies for not even showing the Before and After screenshots here. My knowledge and/or system does not allow that at this time.)
Regards.
Sketcher hides gridlines
- Sketcher, Partial Grid Lines, Before.png (3.98 KiB) Viewed 2071 times
- Sketcher, Partial Grid Lines, After.png (1.93 KiB) Viewed 2071 times
- Sketcher_hides_gridlines_ap7b.pdf
- (37.91 KiB) Downloaded 48 times
Re: Sketcher hides gridlines
That's an issue that's been there a long time, and there have been many topics about it. Basically, after the first item is added to the sketch, the grid will automatically re-size to it. The workaround is to create a large rectangle that is big enough for a "work area" in which the grid will be visible (but you need to close the sketch then re-open it to see the grid re-size). You only have to delete the rectangle once you don't need it anymore.
But FYI, as far as I know most commercial parametric CAD programs with a constraint-based sketcher don't provide a grid at all. It is only there for visual reference. For me the snap-to-grid option is a travesty because it creates the false impression that you sketch is fixed - it is not, only applying constraints will do that.
Those blasted templates...Cyber3DK wrote:Specific complaint: Sketcher is not rotating the drawing to make a line horizontal
Humor somewhat aside, someone already submitted a ticket about that. See here:
issue #1271
issue #1271
Thanks. Let's close this thread and wait for issue #1271 to be resolved.
If you put the issued in "bug" tags it will be linked.
issue #1271
[bug]1271[/bug]
"fight the good fight"
Thanks.
Do I need to repeat my original message in the Forum?
No, we all learn as we go. Thanks for taking notice.Cyber3DK wrote:Do I need to repeat my original message in the Forum?
