Line from 2 dots
Re: Line from 2 dots
It looks also to me because i google "No SWIG wraped library loaded freecad" and it shows some sources that only includes swig 1.x
That's an error message we write out in FreeCAD if the corresponding Swig interface cannot be found.
FYI: Querying the C++ internals of a Swig python module is a pain. For every minor release the API completely changes. On Debian that's normally not a problem because you have only one Swig version system-wide but on Windows e.g. you cannot rely on this. So, you need a general way to find out what the Swig version is. In FreeCAD the solution is a bit crude because we read in the generated python file and get the Swig number from there.
Werner, they seem to have the same problem on debian:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=646374
and another same bug report here (which concerns the same debian version):
http://sourceforge.net/apps/mantisbt/fr ... php?id=637
I'm running the same debian with swig2 and everything runs/compiles fine... Should we tell the debian people to simply issue a new build?
Hi Yorik, the issue was fixed here: http://free-cad.git.sourceforge.net/git ... 9ecda99d3b
Okay, thanks!
Thanks also for replying to the debian bug, I was unsure of what to tell there...
Did you make corecktion of that SWIG 2.x bug?
Demaxfa
Demaxfa
I seeing that you corect the bug and now what compile from source or replace that source fikle or something other??
Dem
Dem
