Inconsistencies in Part API *At methods
crobar
Post by crobar »
I was attempting to improve the docstring for some Part api functions, but ran into some trouble. I've noticed that the behaviour of the valueAt, tangetAt etc. functions is not consistant. Consider the code and output below:
import Draft
import Part
from FreeCAD import Vector
bez_edge = Draft.makeBezCurve([Vector (0.0, 0.0, 0.0), Vector (0.5, 0.0, 0.0), Vector (1.0, 0.5, 0.0), Vector (1.0, 1.0, 0.0)]).Shape.Edges[0]
print ("bez_edge.valueAt (1.0): {}".format (bez_edge.valueAt (1.0)))
print ("bez_edge.valueAt (1.0 * bez_edge.Length): {}".format (bez_edge.valueAt (1.0 * bez_edge.Length)))
line_edge = Part.makeLine (Vector (0.0, 0.0, 0.0), Vector (1.0, 1.0, 0.0))
Part.show (line_edge)
print ("line_edge.valueAt (1.0): {}".format (line_edge.valueAt (1.0)))
print ("line_edge.valueAt (1.0 * line_edge.Length): {}".format (line_edge.valueAt (1.0 * line_edge.Length)))
circle_edge = Part.makeCircle (1.0, Vector (1.0, 0.0, 0.0), Vector (0.0, 0.0, 1.0), 0, 90)
Part.show (circle_edge)
print ("Part.makeCircle (1.0, Vector (1.0, 0.0, 0.0), Vector (0.0, 0.0, 1.0), 0, 90)")
print ("circle_edge.valueAt (1.0): {}".format (circle_edge.valueAt (1.0)))
print ("circle_edge.valueAt (1.0 * circle_edge.Length): {}".format (circle_edge.valueAt (1.0 * circle_edge.Length)))
circle_edge = Part.makeCircle (1.0, Vector (2.0, 1.0, 0.0), Vector (0.0, 0.0, 1.0), 90, 180)
print ("Part.makeCircle (1.0, Vector (2.0, 1.0, 0.0), Vector (0.0, 0.0, 1.0), 90, 180)")
output
bez_edge.valueAt (1.0): Vector (1.0, 1.0, 0.0)
bez_edge.valueAt (1.0 * bez_edge.Length): Vector (0.465441057817615, 1.7406270428980575, 0.0)
line_edge.valueAt (1.0): Vector (0.7071067811865475, 0.7071067811865475, 0.0)
line_edge.valueAt (1.0 * line_edge.Length): Vector (1.0, 1.0, 0.0)
circle_edge.valueAt (1.0): Vector (1.5403023058681398, 0.8414709848078965, 0.0)
circle_edge.valueAt (1.0 * circle_edge.Length): Vector (1.0, 1.0, 0.0)
circle_edge.valueAt (1.0): Vector (2.5403023058681398, 1.8414709848078965, 0.0)
circle_edge.valueAt (1.0 * circle_edge.Length): Vector (2.0, 2.0, 0.0)
The correct output in every case should be Vector (1.0, 1.0, 0.0), but the input argument expected differs in whether you must scale by the length of the curve or not, and the circle behavior is even less intuitive for arc segments. It still acts like the full circle.
Re: Inconsistencies in Part API *At methods
Post by wmayer »
It seems you made the assumption that for the parameter 0 you get the curve's start point and with the value of its length you get the end point. This assumption is wrong!
The parameter range in which a curve is defined do you get with the attributes FirstParameter and LastParameter. It depends on the type of geometry what this range can be. E.g. for lines it's usually [0, length], for infinite curves like hyperbolas or parabolas it's always ]-inf, +inf[, for full ellipses or circles it's [0, 2*PI]. And for B-splines it can be everything.
So again never rely on geometry type or geometrical properties, all what counts is FirstParameter and LastParameter, nothing else.
crobar
Post by crobar »
wmayer wrote:It seems you made the assumption that for the parameter 0 you get the curve's start point and with the value of its length you get the end point. This assumption is wrong!
ok, that clarifies things, thanks.
