New libpacks for Windows with VTK and OCCT7 by sgrogan
yves78
Re: New libpacks for Windows with VTK and OCCT7 by sgrogan
Postby yves78 » Fri Mar 31, 2017 7:44 pm
I was away, and just tested your way of building freecad.
It worked perfectly. I just have two remarks which for my opinion could be helpful for newbies :
- "14) Copy the bin subdirectory to the root of the build folder."
You should specify which bin subdirectory you mean.
You can reuse the same item in CompileOnWindows page, which is : "Copy libpack\bin folder into the new build folder CMake created"
- "16) There will be 2 drop downs in the VS toolbar menu. Change Debug to Release.
Click the dropdown for Win32 and “Configuration Manager...” From the “Active solution
platform” dropdown choose new, then from the “Type or select the new platform” dropdown select
“x64” Close all sub-menus."
I changed debug to release, but the dropdown was already on X64, no need to switch from Win32 to x64 : may be it could specified as
optional, if x64 is not already set ?
Thanks again !
peterl94
Postby peterl94 » Sat Jul 22, 2017 2:12 pm
I've patched netgen 5.3 to work with occt7 (it should work with 7.1, but I have only tested with 7.0 in the libpack). The code is here: https://github.com/peterlama/netgen/tree/5.3-occt7-win. In addition to applying wmayer's and vejmarie's changes, I have modified the project file and install script to makes things more convenient. I would have used netgen 6.2, but I read somewhere it uses C++11 features that don't work with VS 2013.
Install instructions:
1. Checkout branch 5.3-occt7-win in https://github.com/peterlama/netgen.git
2. Open netgen\windows\nglib_config.props in a text editor and change <PrefixPath> for the x64 configuration to the path of FreeCADLibs_11.5.2_x64_VC12 (e.g C:\Users\peter\freecad\FreeCADLibs_11.5.2_x64_VC12). The location of the occt include folder is specified in nglib_config.props too, if you need to change it.
3. Open nglib.sln in VS 2013
4. Build the Release(OCC)|x64 or Debug(OCC)|x64 configuration.
5. The library and headers will be installed to netgen\nglib-instOCC_x64
Note that the Win32 configuration with FreeCADLibs_11.5.1_x86_VC12 is not working at the moment. I haven't found out why yet.
My windows 7 install is broken currently, or else I would provide a pre-compiled package.
I hope it works for you guys.
sgrogan
Postby sgrogan » Sat Jul 22, 2017 2:24 pm
Thanks Peter!! I think I still have a non-portable path in the 11.5.1 build. Please don't spend time on this, I still need to build OCCT 7.1 with wmayers patch to re-name the debug libs properly.
Speaking of debug libs, has anyone found a solution for VTK debug libs, similar to what wmayer has provided for OCCT?
peterl94
Postby peterl94 » Sat Jul 22, 2017 2:33 pm
I recently discovered cmake has a built-in variable for doing this. No patching required, just set CMAKE_DEBUG_POSTFIX=d
saso
Postby saso » Sat Jul 22, 2017 4:00 pm
Great! This one was hanging in the air for a long time :)
sgrogan
Postby sgrogan » Sun Jul 23, 2017 1:51 pm
Fantastic! Thanks again Peter :)
Postby wmayer » Sun Jul 23, 2017 2:25 pm
peterl94 wrote:I would have used netgen 6.2, but I read somewhere it uses C++11 features that don't work with VS 2013.
https://forum.freecadweb.org/viewtopic. ... 10#p139222
Cool! Never heard of that one.
sgrogan
Postby sgrogan » Mon Jul 24, 2017 11:31 pm
OS: Windows 7
Version: 0.17.11654 (Git)
Hash: 81bdb1f276540427872c72d2033c3f400a89a626
Python version: 2.7.8
OCC version: 7.0.0
First time in a long time I've been able to compile FC w/nglib on Win!
I have a problem with OCCT7.1, I'll post more on this later.
Thanks again peterl94, this has been kicking my ass for a long time.
peterl94
Postby peterl94 » Wed Jul 26, 2017 12:32 am
Just tried it myself. It should work now with this commit.
sgrogan
Postby sgrogan » Thu Jul 27, 2017 8:54 pm
Thanks everyone that worked on this, and a special thanks to Peter for making it so simple that even I can't muck it up ;)
