Part-WB add element to compound
HoWil
Post by HoWil »
Hello,
Why can't one add new elements to an existing compound in part-wb? This is possible e.g. for the fusion operation.
One can add or remove elements by drag-and-drop to a fusion.
Please see the attached example where I would like to add the 'Sphere' by drag-n-drop to the 'Compound'.
Should I create an issue/feature-request on the tracker?
Bildschirmfoto von »2017-07-22 19-36-56«.png (129.39 KiB) Viewed 2735 times
Thanks in advance,
HoWil
OS: Ubuntu 16.04.2 LTS
Version: 0.17.11622 (Git)
Build type: None
Hash: 5ffe17153d84e5b361ba4c41e56c62977619f589
Python version: 2.7.12
OCC version: 7.1.0
Locale: German/Austria (de_AT)
FC_part-wb_change_compound.fcstd
(9.51 KiB) Downloaded 38 times
Re: Part-WB add element to compound
Post by NormandC »
Hi HoWil,
HoWil wrote: Sat Jul 22, 2017 5:40 pm Should I create an issue/feature-request on the tracker?
I haven't found an existing one, and this has been requested a few times on the forum. So, please do create a feature request, then maybe a developer will pick this up. :)
HoWil
Post by HoWil »
Done ...Please see issue #3136
Post by NormandC »
Great! Thanks!
silopolis
Post by silopolis »
Also looking for this feature, I found this thread as well as a previous one here https://forum.freecadweb.org/viewtopic.php?t=11424 referencing another issue created before http://freecadweb.org/tracker/view.php?id=2498.
I cross referenced the issues in their comments in the tracker.
This would be a great feature addition IMO too because compounds make a powerful way of grouping parts but being unable to add/remove members/children is a pain along the design path. Having to explode/delete then re-create them several time is a burden, and this becomes hardly doable when you have a hierarchy of compounds.
Anyway, thanks for all FreeCAD goodness :)
Jérémie
Post by NormandC »
NormandC wrote: Sun Jul 23, 2017 4:49 pm I haven't found an existing one
Oh boy, this is so embarrassing... As Jérémie wrote, there was an existing feature request, and I'm the one who created it! :oops:
Post by Kunda1 »
HoWiL please mark as [Solved]
Thanks
