Expressions and Renaming of Sketches etc.
Postby chrisb » Tue Aug 08, 2017 6:00 pm
In the attached Model I use Expressions
- I have given the name "R" to the radius of Sketch
- I use it in the second sketch, dividing it by 2 and give that small radius the name "r"
- I pad the second sketch and use an expression Sketch001.r for the length.
Next I want to rename the Sketch001 to something more sensible, let's say "SketchInner"
I go to the Data Tab and delete "001". The problem is, that on every keystroke the name is set - to be seen in the python console. So there is a point where both sketches have the same name. I add "Inner" and leave the input field. I had expected that the second pad would break, but the second sketch breaks as well, because instead of "Sketch.R" it uses now "SketchI.R". The renaming mechanism inserts the first "I" of "Inner".
Is this known or is it worth a ticket?
OS: Mac OS X
Version: 0.17.11740 (Git)
Branch: (detached from 6b05302)
Hash: 6b05302c2e70f191a2a5787f55c5b549155b9824
Python version: 2.7.13
Qt version: 5.6.2
OCC version: 7.1.0
Bildschirmfoto 2017-08-08 um 19.59.26.png (76.63 KiB) Viewed 645 times
ExpressionsRename.FCStd
(10.7 KiB) Downloaded 15 times
eivindkvedalen
Re: Expressions and Renaming of Sketches etc.
Postby eivindkvedalen » Tue Aug 08, 2017 7:41 pm
Yes, please make a ticket for this case.
Eivind
Postby chrisb » Tue Aug 08, 2017 8:34 pm
Postby chrisb » Tue Aug 08, 2017 8:38 pm
Perhaps this could be solved if the changes are applied at the leave event. That's when the recompute starts.
Postby Kunda1 » Mon Aug 14, 2017 2:48 pm
Eivind
Eivind, can I assign this ticket to you?
