Subdivision To N.U.R.B.S. (IGES) for free
Re: Subdivision To N.U.R.B.S. (IGES) for free
Post by wmayer »
Is is possible to import a blender subdivision curve surface and/or nurbs into freecad and have bhem appear as nurbs?
No, but the OP said that he exported an obj file from Blender. So, I wonder what information other than vertexes and faces this obj file contains.
Since I have no clue how to create a subdivision surface in Blender I also asked for the obj to check how its contents look like.
Btw, the Vrml1 file I created from any kind of surface mesh could be loaded into FreeShip. It's just that the IGES output file seems invalid and I am not an IGES expert to see what's wrong.
regis
Post by regis »
wmayer wrote: Sun Aug 13, 2017 2:45 pm
was not even able to obtain a valid vrml file from blender export.
it is quite Odd that one of the areas where blender and freecad marriage&partnership could have proven to be a great solution to this nurb mesh issue in the open source world. no hack as of yet.
Post by wmayer »
Are you sure the file exported from Blender is Vrml1, not Vrml2. FYI, Vrml1 and Vrml2 are two totally different formats and it's important that the file FreeShip should load is Vrml1.
As said above Vrml1 and OpenInventor are very similar and thus the workaround to save as OpenInventor and changing the header is a possible alternative.
regis
Post by regis »
wmayer wrote: Mon Aug 14, 2017 5:41 am
you are right I mistook wrl file but i'm still left with that problem to sort out.
emills2
Post by emills2 »
this is really cool. it would be nice if the process could be streamlined.
i did a little testing on the FCStd pafurijaz loaded loaded, and the NURBS conversion looks really clean. all the degrees are 3, the knot vectors are simple, the pole tables are small (in the few places i looked).
The irregular points are still fairly rough, but i think this is a faithful conversion of the subdivision. the image below is from a low deviation version of pafurijaz's model, exported to stl to eliminate normal smoothing and accentuate the defects at the irregular points.
As it happens, i have an irregular point smoothing tool that already performs slightly better on 3 lines, and hopefully soon also on 5, 6, and 7 lines ;) open source high quality subdivision NURBS are getting closer.
Gift
Post by Gift »
OCC doesn't support Rational B-Spline Surface Entity (Type 128). See: https://www.opencascade.com/doc/occt-7. ... _iges.html
pafurijaz
Post by pafurijaz »
Kunda1 wrote: Sat Aug 12, 2017 12:27 pm This looks useful! Lets document this on the wiki..eh? @pafurijaz would you like to do that ? (I can make you an account if so)
Damn, :shock: I don't often pass here, because I'm busy with personal work (boats design). I'd be glad to document this little trick, let me know something.
One more thing I'm glad that the post has found interest. :lol:
pafurijaz
Post by pafurijaz »
Hi, I may have found the source code in Pascal, for the conversion of subdivision surfaces into IGES
FreeIGESUnit.pas
{    This code is distributed as part of the FREE!ship project. FREE!ship is an               }
{    open source surface-modelling program based on subdivision surfaces and intended for     }
{    designing ships.        }
{    Copyright © 2005, by Martijn van Engeland                                                }
{    e-mail                  : Info@FREEship.org                                              }
{    FREE!ship project page  : https://sourceforge.net/projects/freeship                      }
{    FREE!ship homepage      : www.FREEship.org                                               }
{    This program is free software; you can redistribute it and/or modify it under            }
{    the terms of the GNU General Public License as published by the                          }
{    Free Software Foundation; either version 2 of the License, or (at your option)           }
{    any later version.        }
{    This program is distributed in the hope that it will be useful, but WITHOUT ANY          }
{    WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A          }
{    PARTICULAR PURPOSE. See the GNU General Public License for more details.                 }
{    You should have received a copy of the GNU General Public License along with             }
{    this program; if not, write to the Free Software Foundation, Inc.,                       }
{    59 Temple Place, Suite 330, Boston, MA 02111-1307 USA                                    }
unit FreeIGESUnit;
{$IFDEF FPC}
  {$MODE Delphi}
{$ENDIF}
interface
uses
     {$ifdef Windows}
      Windows,
     {$else}
     LCLIntf, LCLType, LMessages,
     {$endif}
     classes,
     SysUtils,
     DateUtils,
     Forms,
     Dialogs,
     Graphics,
     FreeTypes,
     FreeGeometry;
const ParameterDelimiter = ',';
      RecordDelimiter    = ';';
      LastColumn         = 72;
      LastParameterColumn= 64;
type TFreeIgesString     = string[80];
     TFreeIGESList       = class
                              private
                                 FStartSection              : TStringList;
                                 FGlobalSection             : TStringList;
                                 FDirectorySection          : TStringList;
                                 FParameterSection          : TStringList;
                                 FTerminateSection          : TStringList;
                                 FNumberOfSurfaces          : Integer;
                                 FIGESunits                 : TFreeUnitType;
                                 FMaxCoordinate             : TFloatType;
                                 FSystemID                  : TFreeIgesString;
                                 FFileCreatedBy             : TFreeIgesString;
                                 FFileName                  : String;
                                 procedure FProcessParameterData(Str:AnsiString;ParamData:TStringList);
                              public
                                 procedure Add_Entity_128(NURB:TFreeNURBSurface;ColorIndex:Integer);
                                 function  Add_Entity_314(Color:TColor):Integer;
                                 procedure Clear;
                                 constructor Create;
                                 destructor Destroy; override;
                                 procedure SaveToFile(Filename:String);
                                 property FileCreatedBy  : TFreeIgesString read FFileCreatedBy write FFileCreatedBy;
                                 property FileName       : String read FFileName write FFileName;
                                 property IGESUnits      : TFreeUnitType read FIGESunits write FIGESunits;
                                 property SystemID       : TFreeIgesString read FSystemID write FSystemID;
                           end;
implementation
function ConvertString(Input:AnsiString):AnsiString;
begin
   if Input='' then Result:=''
               else Result:=IntToStr(Length(Input))+'H'+Input;
end;{ConvertString}
function CheckString(Str:AnsiString;MaxLength:integer;SectionCharacter:Char;index:Integer):string;
const Spaces ='        ';
var L,C:Integer;
begin
   L:=Length(Str);
   if L>Maxlength then Str:=Copy(Str,1,MaxLength)
   else if L<Maxlength then
   begin
      C:=Maxlength-L;
      Str:=Str+Copy(Spaces,1,C);
   end;
   Result:=Str+SectionCharacter;
   L:=Length(Result)+Length(IntToStr(Index));
   C:=80-L;
   Result:=Result+Copy(Spaces,1,C)+IntToStr(Index);
end;{CheckString}
function IndexStr(Index,MaxLength:Integer):String;
begin
   Result:=IntToStr(Index);
   while length(Result)<MaxLength do Result:=#32+result;
end;{IndexStr}
// Takes one string containing all the parameter data and splits it up into
// lines of 64 characters
procedure TFreeIGESList.FProcessParameterData(Str:AnsiString;ParamData:TStringList);
var LastCol : Integer;
    Tmp     : AnsiString;
begin
   // split up into lines of 64 characters
   if Length(Str)>0 then if Str[Length(Str)]<>RecordDelimiter then Str:=Str+RecordDelimiter;
   while length(Str)>LastParameterColumn do
   begin
      Tmp:=Copy(Str,1,LastParameterColumn);
      LastCol:=LastParameterColumn;
      while (Tmp<>'') and (Tmp[LastCol]<>ParameterDelimiter) do
      begin
         Delete(Tmp,LastCol,1);
         Dec(LastCol);
      end;
      while length(Tmp)<LastParameterColumn+1 do Tmp:=Tmp+#32;
      Tmp:=Tmp+IndexStr(FDirectorySection.Count+1,7)+'P'+IndexStr(FParameterSection.Count+ParamData.Count+1,7);
      ParamData.Add(Tmp);
      Delete(Str,1,LastCol);
   end;
   if Str<>'' then
   begin
      while length(Str)<65 do Str:=Str+#32;
      Str:=Str+IndexStr(FDirectorySection.Count+1,7)+'P'+IndexStr(FParameterSection.Count+ParamData.Count+1,7);
      ParamData.Add(Str);
   end;
end;{TFreeIGESList.FProcessParameterData}
procedure TFreeIGESList.Add_Entity_128(NURB:TFreeNURBSurface;ColorIndex:Integer);
var K1,K2,M1,M2   : Integer;
    I,J           : Integer;
    C             : Integer;
    Param         : TStringList;
    PROP          : array[1..10] of integer;
    EntityStr     : AnsiString;
    P             : T3DCoordinate;
    function CreateKnotvector(N,Degree:Integer;knots:TFloatArray) :AnsiString;
    var I:Integer;
        Tmp:single;
    begin
       Result:='';
       for I:=1 to Length(Knots) do
       begin
         Tmp:=Knots[I-1];
         if Tmp<0 then Tmp:=0;
         if Tmp>1 then Tmp:=1;
         Result:=Result+ParameterDelimiter+Truncate(Tmp,6);
       end;
    end;{CreateKnotvector}
    function CreateWeightVector(N:Integer):AnsiString;
    var I:Integer;
    begin
       Result:='';
       for I:=1 to N do Result:=Result+ParameterDelimiter+'1.0';
    end;{CreateWeightVector}
begin
   inc(FNumberOfSurfaces);
   Param:=TStringList.Create;
   // Create parametersection
   K1:=Nurb.ColCount-1;
   K2:=Nurb.Rowcount-1;
   M1:=Nurb.ColDegree;
   M2:=Nurb.RowDegree;
   Prop[1]:=0; // not closed in u-dir
   Prop[2]:=0; // not closed in v-dir
   Prop[3]:=1; // rational
   Prop[4]:=0; // not periodic in u-dir
   Prop[5]:=0; // not periodic in v-dir
   C:=(1+K1)*(1+K2); // number of weights
   EntityStr:=IntToStr(128)+ParameterDelimiter+
              IntToStr(K1)+ParameterDelimiter+
              IntToStr(K2)+ParameterDelimiter+
              IntToStr(M1)+ParameterDelimiter+
              IntToStr(M2)+ParameterDelimiter+
              IntToStr(Prop[1])+ParameterDelimiter+
              IntToStr(Prop[2])+ParameterDelimiter+
              IntToStr(Prop[3])+ParameterDelimiter+
              IntToStr(Prop[4])+ParameterDelimiter+
              IntToStr(Prop[5])+
              CreateKnotvector(K1,M1,Nurb.ColKnotVector)+
              CreateKnotvector(K2,M2,Nurb.RowKnotVector)+
              CreateWeightVector(C);
   for I:=1 to Nurb.Rowcount do
   begin
      for J:=1 to Nurb.ColCount do
      begin
         P:=Nurb.Point[J-1,I-1];
         if abs(P.X)>FMaxCoordinate then FMaxCoordinate:=abs(P.X);
         if abs(P.Y)>FMaxCoordinate then FMaxCoordinate:=abs(P.Y);
         if abs(P.Z)>FMaxCoordinate then FMaxCoordinate:=abs(P.Z);
         EntityStr:=EntityStr+ParameterDelimiter+Truncate(P.X,5)+ParameterDelimiter+
                                                 Truncate(P.Y,5)+ParameterDelimiter+
                                                 Truncate(P.Z,5);
      end;
   end;
   FProcessParameterData(EntityStr,Param);
   // First line
   EntityStr:=IndexStr(128,8)+                        // entity nr
              IndexStr(FParameterSection.Count+1,8)+  // pointer to parametersection start
              IndexStr(0,8)+                          // structure
              IndexStr(1,8)+                          // line font pattern
              IndexStr(0,8)+                          // level
              IndexStr(0,8)+                          // view
              IndexStr(0,8)+                          // Transformation matrix
              IndexStr(0,8)+                          // Label display associativity
              '00000000';                             // Visible,independent,geometry,topdown
   EntityStr:=CheckString(EntityStr,LastColumn,'D',FDirectorySection.Count+1);
   FDirectorySection.Add(EntityStr);
   // Second line
              IndexStr(0,8)+                          // Lineweight
              IndexStr(ColorIndex,8)+                 // color
              IndexStr(Param.Count,8)+                // number of lines in parameter section
              IndexStr(0,8)+                          // form number
              IndexStr(0,8)+                          // reserved for future use
              '        '+                             // entity label
              IndexStr(0,8);                          // Entity subscript number
   FParametersection.AddStrings(Param);
   Param.Destroy;
end;{TFreeIGESList.Add_Entity_128}
function TFreeIGESList.Add_Entity_314(Color:TColor):Integer;
var R,G,B         : Integer;
begin
   R:=GetRValue(Color);
   G:=GetGValue(Color);
   B:=GetBValue(Color);
   EntityStr:=IntToStr(314)+ParameterDelimiter+
              Truncate(100*R/255,3)+ParameterDelimiter+
              Truncate(100*G/255,3)+ParameterDelimiter+
              Truncate(100*B/255,3)+ParameterDelimiter+
              ConvertString('');
   // First line
   EntityStr:=IndexStr(314,8)+                        // entity nr
   Result:=-FDirectorySection.Count;
   // Second line
              IndexStr(0,8)+                          // color
   Param.Destroy;
end;{TFreeIGESList.Add_Entity_314}
procedure TFreeIGESList.Clear;
begin
   FStartSection.Clear;
   FGlobalSection.Clear;
   FDirectorySection.Clear;
   FParameterSection.Clear;
   FTerminateSection.Clear;
   FNumberOfSurfaces:=0;
   FMaxCoordinate:=0.0;
   FSystemID:='';
   FFileCreatedBy:='';
   FFilename:='';
end;{TFreeIGESList.Clear}
constructor TFreeIGESList.Create;
begin
   Inherited Create;
   FStartSection:=TStringList.Create;
   FGlobalSection:=TStringList.Create;
   FDirectorySection:=TStringList.Create;
   FParameterSection:=TStringList.Create;
   FTerminateSection:=TStringList.Create;
   Clear;
end;{TFreeIGESList.Create}
destructor TFreeIGESList.Destroy;
begin
   Clear;
   FStartSection.Destroy;
   FGlobalSection.Destroy;
   FDirectorySection.Destroy;
   FParameterSection.Destroy;
   FTerminateSection.Destroy;
end;{TFreeIGESList.Destroy}
procedure TFreeIGESList.SaveToFile(Filename:String);
var Str     : AnsiString;
    TimeStr : string;
    Tmp     : AnsiString;
    Strings : TStringList;
    Index   : Integer;
    LastCol : Integer;
    function CreateTimeStamp:string;
    var Time    : TDateTime;
    begin
       Time:=now;
       // year
       Result:=IntToStr(YearOf(Time));
       // month
       Tmp:=IntToStr(MonthOf(Time));
       if length(Tmp)<2 then Tmp:='0'+Tmp;
       Result:=Result+Tmp;
       // day
       Tmp:=IntToStr(DayOf(Time));
       Result:=Result+Tmp;
       // separator
       Result:=Result+'.';
       // Hours
       Tmp:=IntToStr(HourOf(Time));
       Result:=Result+Tmp;
       // minutes
       Tmp:=IntToStr(MinuteOf(Time));
       Result:=Result+Tmp;
       // seconds
       Tmp:=IntToStr(SecondOf(Time));
       Result:=Result+Tmp;
       Result:=IntToStr(length(Result))+'H'+Result;
    end;{CreateTimeStamp}
begin
   // Create time string
   TimeStr:=CreateTimeStamp;
   // Create the start section
   FStartSection.Add(CheckString('FREE!ship IGES file. (www.freeship.org)',LastColumn,'S',1));
   // Create the global section
   Str:=ConvertString(ParameterDelimiter)+ParameterDelimiter+
        ConvertString(RecordDelimiter)+ParameterDelimiter+
        ConvertString(ChangeFileExt(ExtractFilename(Application.ExeName),''))+ParameterDelimiter+                    // ProductNameSender
        ConvertString(FFilename)+ParameterDelimiter+        // Original filenameh
        ConvertString(SystemID)+ParameterDelimiter+        // Preprocessor
        ConvertString(SystemID)+ParameterDelimiter+        // Preprocessor version
        IntToStr(32)+ParameterDelimiter+        // Integer bits
        IntToStr(38)+ParameterDelimiter+        // Single precision
        IntToStr(6)+ParameterDelimiter+        // Single sign. bits
        IntToStr(308)+ParameterDelimiter+        // Double precision
        IntToStr(15)+ParameterDelimiter+        // Double sign. bits
        ConvertString('')+ParameterDelimiter+        // Post processor
        FloatToStrF(1.0,ffFixed,7,4)+ParameterDelimiter;                                                             // Model scale
   if IGESUnits=fuImperial then Str:=Str+IntToStr(4)+ParameterDelimiter+ConvertString('Feet')+ParameterDelimiter
                           else Str:=Str+IntToStr(6)+ParameterDelimiter+ConvertString('Meters')+ParameterDelimiter;
   Str:=Str+IntToStr(1)+ParameterDelimiter+        // Lineweight graduations
        FloatToStrF(1.0,ffFixed,7,4)+ParameterDelimiter+                                                             // max lineweight
        TimeStr+ParameterDelimiter+        // Time
        FloatToStrF(0.01,ffFixed,7,6)+ParameterDelimiter+                                                            // Minimum resolution
        FloatToStrF(FMaxCoordinate,ffFixed,7,6)+ParameterDelimiter+                                                  // Maximum coordinate
        ConvertString(FileCreatedBy)+ParameterDelimiter+                                                             // Author
        ''+ParameterDelimiter+        // Author organisation
        IntToStr(9)+ParameterDelimiter+        // IGES version 5.1
        IntToStr(1)+ParameterDelimiter+        // draftingstandard=NONE
        TimeStr+RecordDelimiter;
   // split up into lines of max. 72 characters
   Index:=1;
   while length(Str)>LastColumn do
   begin
      Tmp:=Copy(Str,1,LastColumn);
      LastCol:=LastColumn;
      begin
         if pos(ParameterDelimiter,Tmp)=0 then
         begin
            // This must be a stringvalue which spans multiple lines
            Tmp:=Uppercase(Tmp);
            break;
         end else
         begin
            Dec(LastCol);
         end;
      end;
      Tmp:=CheckString(Tmp,LastColumn,'G',Index);
      FGlobalSection.Add(Tmp);
      Inc(Index);
   end;
   if Str<>'' then
   begin
      Tmp:=CheckString(Str,LastColumn,'G',Index);
   end;
   // create the terminate section
   Str:='S'+IndexStr(FStartsection.Count,7)+
        'G'+IndexStr(FGlobalsection.Count,7)+
        'D'+IndexStr(FDirectorysection.Count,7)+
        'P'+IndexStr(FParametersection.Count,7);
   Str:=CheckString(Str,LastColumn,'T',1);
   FTerminateSection.Add(Str);
   Strings:=TStringList.Create;
   Strings.AddStrings(FStartSection);
   Strings.AddStrings(FGlobalSection);
   Strings.AddStrings(FDirectorySection);
   Strings.AddStrings(FParameterSection);
   Strings.AddStrings(FTerminateSection);
   Strings.SaveToFile(ChangeFileExt(Filename,'.igs'));
   Strings.Destroy;
end;{TFreeIGESList.SaveToFile}
end.
pafurijaz
Post by pafurijaz »
I also found this, but I do not know whether it is useful.
Object shape reconstruction through NURBS surface interpolation
brothermechanic
Post by brothermechanic »
Coul'd you try ShipCAD? This is port of FreeShip to Qt5.
https://github.com/gpgreen/ShipCAD
