FreeCAD FEM moment of inertia & axial torsion
blubee
Postby blubee » Mon Aug 21, 2017 2:08 am
I am trying to model the force of a motor on a central pipe [hexagon and cylindrical] along with some disks.
I would like to see how many pascals it would take for any of the parts to reach failure. I am using standard medium carbon steel, I've attached two files they both have a gmsh with a max size of 1.00000000 mm so it might be a bit slow to open.
I'd like to see what's the maximum radial torsion I could apply to a gear connected to the shaft at the three different sections. I would also like to see how I can do the same for the hexagon hole in the inner disk as well as the six holes that would hold more stabilizing pins going horizontally.
Actually the files are too large to attach with the gmsh and analysis. I'll add the files without gmsh and analysis.
Would anyone be able to guide me through applying a rotational torsion to the pipe to see where they will break?
OS: Ubuntu 17.04
Version: 0.17.11827 (Git)
Build type: None
Hash: ca4488f4387f761df47322038585b23cb5a1bd73
Python version: 2.7.13
OCC version: 7.1.0
pipe.fcstd
(43.91 KiB) Downloaded 31 times
disk.fcstd
(30.04 KiB) Downloaded 30 times
HoWil
Re: FreeCAD FEM moment of inertia & axial torsion
Postby HoWil » Mon Aug 21, 2017 5:49 am
Dear blubee,
I am not sure if applying rotational load does work at the moment... Please see also https://forum.freecadweb.org/viewtopic.php?f=18&t=23778 there you find also some further information in the listed links.
But you can simply create a test case.
Regarding the size of the model you should consider simply deleting the mesh information by right clicking on the mesh object. One can than still remesh your model with the all stored settings.
BR,
Howil
blubee
Postby blubee » Mon Aug 21, 2017 12:54 pm
Dear blubee,
BR,
Howil
Thanks, with that I attempted to do a little test. Would anyone be willing to take a look at this results file?
https://filetea.me/n3wU1YLHUMpSPOYoV6TSFLh1Q
I am trying to figure out how to get the data that I need.
There are constraints on both ends of this pipe, then there's force applied [500] is that MPa? Then after a little while I get the result which looks like this:
when I animate the displacement it gets really strange results:
I just want to know what's the MPa that would cause any part of this model to fail.
When applying force, it only asks for a number; is that Newtons, N.M, N.M^2, MPa, ft-lbs, etc?
UR_
Postby UR_ » Mon Aug 21, 2017 3:22 pm
The funny part of this analysis is, you caused millions of floating point operations, done by ccx, just to obtain this:
Shear stress rod under torque.png (2.66 KiB) Viewed 1029 times
:shock:
UR_
Postby UR_ » Mon Aug 21, 2017 3:55 pm
Are you talking about this input box?
FEM Constraint Force.png (11.6 KiB) Viewed 1020 times
As you can see, there is asked for an "area load". Load's unit is Newton. This load will be distributed equally to selected face.
BTW this issue is on the run:
blubee
Postby blubee » Mon Aug 21, 2017 4:17 pm
Shear stress rod under torque.png :shock:
Well that doesn't look good on me, but i am learning. I'm a programmer first, fell into physics sorta out of necessity.
Thank you for the clarification.
thschrader
Postby thschrader » Mon Aug 21, 2017 6:44 pm
EDIT 21.08.2017 (UR_, I am getting older... :oops: )
Hello blubee,
according to the above formula from UR_ for calculating shear-stress under torsional loading, you can
apply a torsion-loading of 0,231 kNm at the 20 mm transmission (when using steel S235 with a maximum
allowable shear stress of 136 MPa). The distance between the holes in the disk and the axis of the transmission is 30 mm,
so you must apply a load of 7100 N at both holes to get the Torsion of 0,231 kNm at both ends of the transmission.
If you run the calculation with your modell, you will get good results (plot: shear-stress). Attached is the modell
with the cleared mesh (doubleclick on mesh, mesh it hyperfine as you did before and have a pizza during ccx-run... :) )
regards thomas
pipe_neu.fcstd
(85.79 KiB) Downloaded 33 times
Postby bernd » Mon Aug 21, 2017 6:51 pm
UR_
Postby UR_ » Mon Aug 21, 2017 7:02 pm
dann kannst du beim Rechenlauf in Ruhe eine Pizza essen...
That's right.
But can you please translate this to english. ;)
