Improvement of rectangular selection
SparkyCola
Postby SparkyCola » Thu Sep 28, 2017 6:55 pm
So in addition to the "normal" selection which is currently there I'd like to add a selection that selects the whole object when it's only touched on one corner/line/point.
It could be switched like in SolidWorks where it depends if you make the selection bottom to top or top to bottom (not sure which was which). Using a key like the M key is another option however the start-point method seems simpler to me (especially when you have to switch a lot between the modes).
bejant
Re: Improvement of rectangular selection
Postby bejant » Fri Sep 29, 2017 1:33 am
AutoCAD has a similar behavior - there is (or was) a ticket in the tracker for this (and I may have commented on it) but I don't know what became of it. Let me check...
Edit: Sorry - that will have to wait because the tracker is too slow for me now. The ticket might have been submitted by Oldestfox but I'm not sure.
Postby wmayer » Fri Sep 29, 2017 6:16 am
This is already implemented with the difference that it's not top <=> bottom/bottom <=> top but left <=> right/right <=> left.
bejant
Postby bejant » Sat Sep 30, 2017 2:04 am
I didn't know - thanks! I just tested it and think I have found a glitch which can be replicated by doing this:
Create the default Cube.
Create a Sketch (I used the X-Y Plane at the default Z = 0) and make a zig-zag pattern larger than the footprint of the Cube, something like this:
Now try the right-to-left Box Select on a portion of the Cube without intersecting the Sketch geometry and the all the Sketch geometry is selected. I'm guessing right-to-left selection uses something like a bounding box instead of using the geometry itself?
OS: Ubuntu 16.04.3 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.12223 (Git)
Build type: None
Hash: 917e61a3be12f3316d571ebf6fd6e3c537691c14
Python version: 2.7.12
OCC version: 7.1.0
Postby chrisb » Sat Sep 30, 2017 5:24 am
How do you perform this selection anyway? I guess it's a rubberband selection, which I don't have at all. It exists only in Sketcher.
I use the Gesture mouse model.
Postby wmayer » Sat Sep 30, 2017 7:56 am
For performance reasons it doesn't check each element of an object if it's inside the rectangle but instead it just uses an object's (projected) bounding box.
peterl94
Postby peterl94 » Sat Sep 30, 2017 12:08 pm
Shift + B starts the box select command (edit menu).
Postby Kunda1 » Sat Sep 30, 2017 12:28 pm
sort of unrelated but here's another box issue that is open on the tracker: issue #2706 - Box selection does not select dimension or text
SparkyCola
Postby SparkyCola » Sat Sep 30, 2017 1:24 pm
I can't get Sketcher to select the whole line/circle/element when I only box a part of it, no matter from where I start the selection. That is what I was looking for.
GeneFC
Postby GeneFC » Sat Sep 30, 2017 3:32 pm
That sort of behavior is a choice made by the program designers. I have some graphics-related programs that work on the "touch" method and other that require the entire object to be selected.
There are pluses and minuses to both approaches. The "touch" method sounds easy, but it also makes it very easy to select unwanted elements that may have portions close to the desired selection. The "entire" method is generally more definite for selection, but it is slightly more work.
I don't see an obvious advantage for one method over the other.
Just learn the "rules" and go forward.
Gene
cron
