Update on the development of the OpenFOAM CFD workbench (CFDOF)
Moderator: oliveroxtoby
thschrader
Re: Update on the development of the OpenFOAM CFD workbench (CFDOF)
Post by thschrader »
Hello Oliver,
I tried to do the same simulation like the "flooding-tank" tutorial from Jozsef Nagy on YT.
(The tank is flooded with water against gravity, like a fountain. The result should look like
the picture below). The calculation allways stops after 30s with openFOAM fatal error.
Probably I do something wrong with the field initialization or my workflow is garbage.
Please have a look at the FC-file. After writing the case you will see in the alpha.water-dict,
that the inlet/outlet values are not assigned (like in the alpha.water from tutorial), there
is a "TODO" entry. The blue cube is the initialization-zone for water.
regards Thomas
(the error "out of scope" on the mesh in tree has no effect...)
testCFD.FCStd
(183.19 KiB) Downloaded 129 times
oliveroxtoby
Post by oliveroxtoby »
thschrader wrote: Mon Oct 02, 2017 9:03 pm I tried to do the same simulation like the "flooding-tank" tutorial from Jozsef Nagy on YT.
I thought that the alpha initialisation zone would cause the inlet alpha value to be set to 1, but I see that it doesn't work out like that.
The alpha inflow value can now be set in the boundary condition, and a couple of bugs are fixed. Should work now.
testCFD.FCStd
(182.02 KiB) Downloaded 139 times
thschrader
@Oliver, short info
after updating CFDOF via addon-manager, close/restart FC:
try to mesh a cube. snappyhexMesh breaks,
gmsh/cfmesh works. system:
Version: 0.17.12284 (Git)
Hash: 2244292552c004e6b506af9e1e98d3423e524ee7
Python version: 2.7.8
OCC version: 7.1.0
oliveroxtoby
thschrader wrote: Wed Oct 04, 2017 1:36 pm @Oliver, short info
Thanks - fixed.
Worufu
Post by Worufu »
Is it possibile to have the "volumetric flow rate" and "mass flow rate" also in outlet as in inlet?
oliveroxtoby
Worufu wrote: Fri Oct 06, 2017 10:07 am Is it possibile to have the "volumetric flow rate" and "mass flow rate" also in outlet as in inlet?
At present the OpenFOAM boundary condition is only designed as an inlet (all three components of velocity are constrained); of course you can achieve much the same effect with the 'uniform velocity' outlet. If you would be interested, you could code up a new BC which allows users to specify mass flow rate and divides this by density and area to get the normal component of velocity.
Worufu
Post by Worufu »
oliveroxtoby wrote: Mon Oct 09, 2017 7:48 am
Thank for the information. It can be a good start to put me on coding in freecad. In your opinion is it possible to code all through python?
makkemal
Post by makkemal »
believe this post is actually part of this thread
https://forum.freecadweb.org/viewtopic.php?f=18&t=24857
oliveroxtoby
Worufu wrote: Tue Oct 10, 2017 3:38 pm
Great! Yes, definitely possible in python.
oliveroxtoby
makkemal wrote: Wed Oct 11, 2017 4:43 pm believe this post is actually part of this thread
Thanks for the notification.
