Compiling on Mac OS Yosemite 10.10.5
nyholku
Post by nyholku »
slowly recovering from summer ;) and considering getting back to work on FreeCAD and my Navicube.
I don't know if I've lost my memory completely but I was under the impression that I could use FreeCAD under Mac OS Yosemite 10.10.5
Now, looking at the precompiled binaries for 0.17 they work only in 10.11 or later.
UpgradingMac OS is going to be major hassle so not going to do that in a hurry.
Before I see if I can compile 0.17 on 10.10.5 I thought I'd as first are there any known
road blocks i.e. why is it that the pre compiled 0.17 only work on 10.11 or later.
wbr Kusti
peterl94
Re: Compiling on Mac OS Yosemite 10.10.5
Post by peterl94 »
You remember correctly. I changed it to 10.11 because a lot of homebrew formulas didn't have bottles for 10.10 anymore and it took too long to compile them from source on travis ci. Everything still compiles fine on 10.10, though.
nyholku
Post by nyholku »
Ok, great, thanks!
wbr Kusti
nyholku
Post by nyholku »
Since my previous successful build environment has rotted in the half year I've been away from this project I decided to start over. Hate bit rot!
I completely erased homebrew including all the taps.
I dowloaded the latest source from github.
I specifically did NOT try to install the FreeCAD dependencies before hand as I wanted to try Qt5.
0.17 support Qt5 right?
So the first CMake failed with:
 Qt4 libraries not found.
So I installed Qt5 (up to this point there is no Qt in this system):
brew install qt5
==> Downloading https://download.qt.io/official_releases/qt/5.9/5.9.2/single/qt-everywhere-opensource-src-5.9.2.tar.xz
==> Downloading from http://master.qt.io/archive/qt/5.9/5.9.2/single/qt-everywhere-opensource-src-5.9.2.tar.xz
######################################################################## 100.0%
==> Downloading https://raw.githubusercontent.com/Homebrew/formula-patches/e8fe6567/qt5/restore-pc-files.patch
==> Downloading https://raw.githubusercontent.com/Homebrew/formula-patches/a627e0a/qt5/QTBUG-56814.patch
==> Patching
==> Applying restore-pc-files.patch
patching file qtbase/mkspecs/features/qt_module.prf
Hunk #1 succeeded at 264 (offset 19 lines).
==> Applying QTBUG-56814.patch
patching file qttools/src/macdeployqt/shared/shared.cpp
patch unexpectedly ends in middle of line
Hunk #1 succeeded at 821 with fuzz 2 (offset 18 lines).
==> ./configure -verbose -prefix /usr/local/Cellar/qt/5.9.2 -release -opensource -confirm-license -system-zlib -qt-libpng -qt-libjpeg -qt-freetype -qt-pcre -nomake tests -no-r
==> make
==> make install
==> Caveats
We agreed to the Qt opensource license for you.
If this is unacceptable you should uninstall.
This formula is keg-only, which means it was not symlinked into /usr/local,
because Qt 5 has CMake issues when linked.
If you need to have this software first in your PATH run:
  echo 'export PATH="/usr/local/opt/qt/bin:$PATH"' >> ~/.bash_profile
For compilers to find this software you may need to set:
    LDFLAGS:  -L/usr/local/opt/qt/lib
    CPPFLAGS: -I/usr/local/opt/qt/include
For pkg-config to find this software you may need to set:
    PKG_CONFIG_PATH: /usr/local/opt/qt/lib/pkgconfig
==> Summary
🍺  /usr/local/Cellar/qt/5.9.2: 9,021 files, 282.4MB, built in 112 minutes 52 seconds
Gee what waste of CPU cycles and human time building from source is.
(As noted before the world of C/C++ tool chain is broken beyond repair
and this is not FreeCAD's fault. Nobody's fault, it just is).
Above some patch seemed to fail in some way (did understand that and did not investigate).
Should I do something with those LDFLAGS/CPPFLAGS as instructed and what and where is the proper place to do that?
At this point CMake FreeCAD still fails to find Qt (and it looks like it would prefer Qt4):
cmake -DBUILD_ROBOT="0" -DFREECAD_USE_EXTERNAL_PIVY="1" -DBUILD_FEM_NETGEN="1"  -DFREECAD_CREATE_MAC_APP="1" ../FreeCAD-git
-- Compiler: Clang, version: 7.0.2.7000181
-- Force BOOST_PP_VARIADICS=1 for clang
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
CMake Warning at CMakeLists.txt:316 (message):
  BUILD_PATH requires BUILD_PART;BUILD_ROBOT each be ON, but BUILD_ROBOT is
  "0"
Call Stack (most recent call first):
  CMakeLists.txt:335 (REQUIRES_MODS)
-- Detected Homebrew install at /usr/local
-- Boost version: 1.65.1
-- Found the following Boost libraries:
--   filesystem
--   program_options
--   regex
--   signals
--   system
--   thread
--   chrono
--   date_time
--   atomic
-- Found Xerces-C: /usr/local/lib/libxerces-c.so
-- PyCXX found:
--   Headers:  /Users/nyholku/FreeCAD2/FreeCAD-git/src
--   Sources:  /Users/nyholku/FreeCAD2/FreeCAD-git/src/CXX
-- -- Found OCE/OpenCASCADE version: 7.1.0
-- -- OCE/OpenCASCADE include directory: /usr/local/include/opencascade
-- -- OCE/OpenCASCADE shared libraries directory: /usr/local/lib
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5
-- Checking for one of the modules 'hdf5-serial'
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Checking for one of the modules 'ompi-cxx'
CMake Warning at CMakeLists.txt:709 (message):
  mpi.h was not found.  Check for error above.
-- Check for medfile (libmed and libmedc) ...
-- Cannot find NETGEN header files.
-- Cannot find NETGEN library.
-- Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR EIGEN3_VERSION_OK) (Required is at least version "2.91.0")
Eigen3 not found.
-- Found unsuitable Qt version "" from NOTFOUND
Qt QTOPENGL library not found.
Qt QTSVG library not found.
Qt QTUITOOLS library not found.
Qt QTWEBKIT library not found.
Qt QTGUI library not found.
Qt QTXML library not found.
Qt QTNETWORK library not found.
Qt QTCORE library not found.
CMake Error at CMakeLists.txt:781 (MESSAGE):
-- Configuring incomplete, errors occurred!
jmaustpc
Post by jmaustpc »
Since this topic is about compiling, I moved it from Dev forum to here.
nyholku wrote: Thu Nov 09, 2017 7:54 am 0.17 support Qt5 right?
Yes, but there are issues, I think the main issue is one of the associated libs is not yet feature complet with its earlier qt4 version, also on OSX there were some qt4 bugs so it's not perfect either.
sgrogan
Post by sgrogan »
There is a CMake flag BUILD_QT5, on Win at least it's un-checked by default. If you can use CMake-gui it will help working through these issues.
Also QT5 builds for OSX are available: https://github.com/FreeCAD/FreeCAD/rele ... g/0.17_pre they are .dmg's and are available for every commit to master. There have been some auto build issues lately, that may be fixed already, but if the file is less than 200+ MB there is probably a problem and shouldn't be downloaded.
"fight the good fight"
f3nix
Post by f3nix »
Hi!
nyholku wrote: Thu Nov 09, 2017 7:54 am At this point CMake FreeCAD still fails to find Qt (and it looks like it would prefer Qt4):
You have to use -DBUILD_QT5=1
You should start in a new build folder since adding this flag won't make it work. The CMake cache is "polluted" with Qt4 stuff.
HTH.
Cheers,
Mateusz
nyholku
Post by nyholku »
@sgrogan the pre-built binaries are nice but they don't work with MacOS Yosemite so I can't use them and the final goal, besides learning to use FreeCAD, is to be able to contribute something.
@f3nix,@sgrogan thanks for the -DBUILD_QT5=1 info, I will try that next
peterl94
Post by peterl94 »
In addition to setting BUILD_QT5, you also have to add the qt5 cmake prefix to the cmake prefix path. It will also save you a bunch of trouble if you use the freecad formula to install the needed libraries. You need to install qt 5.6 instead of the latest 5.9 because pyside2 does not work with qt 5.9 yet. This is basically how it is done on travis:
brew tap homebrew/science
brew tap freecad/freecad
brew install --only-dependencies freecad
brew install --only-dependencies freecad #Ensure all dependencies are satisfied
cmake -DCMAKE_BUILD_TYPE="Release" \
  -DBUILD_QT5=1 \
  -DCMAKE_PREFIX_PATH="/usr/local/Cellar/qt@5.6/5.6.2/lib/cmake"  \
  -DFREECAD_USE_EXTERNAL_KDL=1  \
  -DBUILD_FEM_NETGEN=1 \
  ../FreeCAD-git
nyholku
Post by nyholku »
@peterl94
thanks, that (almost) did it!
I installed Qt 5.6 like this:
curl -O https://raw.githubusercontent.com/Homebrew/homebrew-core/fdfc724dd532345f5c6cdf47dc43e99654e6a5fd/Formula/qt5.rb
brew install ./qt5.rb
I also had to install eigen which your instructions apparently missed:
brew install eigen
I then built it using:
cmake -DBUILD_QT5="1" -DBUILD_ROBOT="0" -DFREECAD_USE_EXTERNAL_PIVY="1" -DBUILD_FEM_NETGEN="1"  -DFREECAD_CREATE_MAC_APP="1" ../FreeCAD-git
Now it builds cleanly and launches without problem!
Great, thank you very much.
Now if I only could locate those nice Onshape like icons that someone had made and could install those... ;)
wbr Kusti
PS Here is usefull SO entry re installing older versions of Qt:
https://stackoverflow.com/questions/401 ... -homebrew
