Update on the development of the OpenFOAM CFD workbench (CFDOF)
Moderator: oliveroxtoby
thschrader
Re: Update on the development of the OpenFOAM CFD workbench (CFDOF)
Postby thschrader » Thu Nov 02, 2017 5:17 pm
Just downloaded the latest 0.17.12539 dev-snapshot.
When loading an existing case, the InitialiseFields dialog
is inactive. With my "old" 0.17.12431 everything works fine.
(@Oliver: the loaded case is the "damBreak"-tutorial from the
openFoam user guide. With the cfd-of wb you only need 15 min to
generate the case... :) paraview-results below calculated with 0.17.12431)
Another wish: everytime when using a new dev-snapshot, I manually (must)
copy the gnuplot-folder/gnuplot...egg-info file from my previous version into
the bin/lib/site-packages folder of the new FC-version. Please add
the gnuplot files as a standard to FC, thanks.
System used:
Version: 0.17.12539 (Git)
Hash: adc24f8c8ffb81ce5b85af9ac6ed67054ae0030d
Python version: 2.7.8
OCC version: 7.1.0
HoWil
Postby HoWil » Fri Nov 03, 2017 8:09 pm
Hi Thomas, nice pics.
In case you still have all your 'transfered'/rebuilt openFoam-tutorial- models, you could post it here or in the wiki!?
BR,
Wilfried
thschrader
Postby thschrader » Fri Nov 03, 2017 9:31 pm
BR,
Wilfried
Hi Wilfried,
here are two cases lower than 500KB.
damBreak uses the same parameters like in the openfoam user guide.
In TankFlooding the g-vector points in -z direction. CFD-OF uses the -y direction as default,
after writing the case, edit the g-dict and overwrite the vector.
In both cases you must edit (after case writing) the transportProperties-dict, the nu/sigma-values are
generated with zeros(?). Then run solver. See pics below. I hope it will work... :)
It is not necessary to use the parallel-run option.
I used the 0.17.12431, see error in 0.17.12539 from post above.
Regards Thomas
damBreak.FCStd
(283.41 KiB) Downloaded 41 times
TankFlooding.FCStd
(150.28 KiB) Downloaded 42 times
thschrader
Postby thschrader » Fri Nov 03, 2017 9:39 pm
@HoWil:
be patient, even with a very coarse mesh the damBreak-case needs more
than 2000 sec runtime..(1 sec simulation, parallel run ;) )
oliveroxtoby
Postby oliveroxtoby » Sun Nov 05, 2017 7:37 pm
Thanks for reporting. Should be fixed now. 12539 or later is now required.
thschrader wrote: (@Oliver: the loaded case is the "damBreak"-tutorial from the
Glad to hear!
thschrader wrote: Another wish: everytime when using a new dev-snapshot, I manually (must)
You should be able to use the "Download / install gnuplot.py" button on the CFD preferences page to do this.
thschrader wrote: Please add
Not my call to make. It may be better to move to matplotlib which is already included in FreeCAD. Please consider helping out - see some discussion near the end of the thread https://forum.freecadweb.org/viewtopic. ... 6&start=60
wafi
Postby wafi » Sat Nov 11, 2017 2:55 pm
Hi Oliver
seems to be new problems in the meshing module, I not able to mesh and I getting following failure message:
Running the Python command 'Cfd_MeshCartFromShape' failed:
File "/home/peter/.FreeCAD/Mod/CfdOF/_CommandCfdMeshCartFromShape.py", line 67, in Activated
FreeCADGui.doCommand("FemGui.getActiveAnalysis().addObject((App.ActiveDocument.ActiveObject)")
('unexpected EOF while parsing', ('<string>', 1, 71, 'FemGui.getActiveAnalysis().addObject((App.ActiveDocument.ActiveObject)\n'))
OS: Ubuntu 16.04.3 LTS
Version: 0.17.12570 (Git)
Build type: None
Hash: b01c503c2cb37b2ed4fb848b0f495f599a7b179f
Python version: 2.7.12
OCC version: 7.1.0
oliveroxtoby
Postby oliveroxtoby » Mon Nov 13, 2017 7:36 am
Hi Oliver
My apologies - that one wasn't picked up by our tests. Should be fixed.
shIxx
Postby shIxx » Fri Sep 28, 2018 1:24 pm
Hi guys,
Thank you for your great work.
I just want to say that the dynamic viscosity of air under FluidProperties is always zero since rev.14761
Is that a general issue or ist it because of my FC or PC settings?
thschrader
Postby thschrader » Fri Sep 28, 2018 8:43 pm
Same problem here...
Version: 0.18.14825 (Git)
Hash: a0ff629747d5d73567075821852a8cdaadcf51c5
Python version: 2.7.14
OCC version: 7.2.0
oliveroxtoby
Postby oliveroxtoby » Fri Sep 28, 2018 9:05 pm
Hi guys,
Thank you for reporting this. It should now be fixed.
