GCode Error generated in Pocket_3D operation.
JoshM
Postby JoshM » Thu Nov 09, 2017 9:47 pm
I just generated a job and ran it, and found the issues I'd missed with simulation. I tracked down the issue and found I could reproduce it reliably on my system. I was working on an older version () but checked on latest version and found it remains there as well, so thought I'd mention it.
What I found is that if I add geometry that Freecad isn't able to work with, it throws in the following GCode, either at the beginning or end of the operation--not sure what impacts where it is appended, as I've seen both:
G0 Z24.000000
G0
G0 Z0.000000
G0 Z24.000000
This had unpleasant results;)...
I had Base-Body-PotentiometerCap_Mold.Face4 included and that causes that GCode to be prepended or appended. BTW, it doesn't show up in the FC-Path lines. It was there when I ran GWizard simulation but I missed it in the mess of lines...
I can't append my project because it's too big--about 2.1 Megs. It doesn't compress much. Not sure how to do that, so am attaching a screenshot for now...
Thanks,
Josh
Found it using this version:
Version: 0.17.12431 (Git)
Hash: c397aee9ed3efcb2e33fa719313c98cc4867cf32
Python version: 2.7.8
OCC version: 7.1.0
Tested that it still exists in this version.
Version: 0.17.12560 (Git)
Hash: 71836f4b37a29c1ee54b1bd681cb9b687901cc96
OCC version: 7.1.0
Re: GCode Error generated in Pocket_3D operation.
Postby Kunda1 » Thu Nov 09, 2017 9:49 pm
JoshM wrote:I can't append my project because it's too big--about 2.1 Megs. It doesn't compress much. Not sure how to do that, so am attaching a screenshot for now...
You can use a 3rd party cloud-based service like dropbox etc...
JoshM
Postby JoshM » Fri Nov 10, 2017 1:59 pm
Thanks Kunda1--appreciate you pointing me in the right direction.
I uploaded my project at: https://ln.sync.com/dl/f66a5ee70/p3grmq ... b-ud592abj
Best Regards,
Josh
mlampert
Postby mlampert » Fri Nov 10, 2017 10:56 pm
I cannot reproduce this, running the following command should turn up at least one of those G0 commands in your design but doesn't:
>>> [cmd for cmd in App.ActiveDocument.Job.Path.Commands if not cmd.Parameters and cmd.Name[0] is not '(' and cmd.Name not in ['G80', 'G90', 'G91', 'G98']]
I presume the error happens in you post processor.
JoshM
Postby JoshM » Fri Nov 10, 2017 11:33 pm
Thanks Mlampert. I'll dig into that Monday when I'm back at work. I appreciate your help.
I did successfully mill my mold on 2nd try--not bad for developmental software that's free. I'm really appreciative of the work you all have done. Right now it's a bit loose, but ultimately workable, and the improvements are fast.
Thanks,
Josh
Postby chrisb » Fri Nov 10, 2017 11:43 pm
Which postprocessor do you use? You can use the "Inspect GCode" tool to view the gcode before postprocessing.
JoshM
Postby JoshM » Sat Nov 11, 2017 12:06 am
Thanks Chrisb. I caught that inspect-GCode later, will use it as you suggest.
I'm using LinuxCNC that I modified a bit: preamble, suppressing tool changes for sequential operations that use same tool, so only on new tool#... either I introduced a bug or it's there in Provided Post. I'll check Monday.
Best,
Josh
JoshM
Postby JoshM » Mon Nov 13, 2017 2:08 pm
Hi Chrisb,
I figured for sure it would be something I messed up in the Post-Processor modification, but your suggestion of using the GCode-Inspection for a particular operation suggests its a bug on the Freecad-Path side of things...
I had selected 3 Faces for that operation, and only 1 was accepted--it appears that for each unaccepted Face, the incorrect GCode G0 Z0.0 is inserted, unless I'm reading into it too much...
Best Regards,
Josh
Postby chrisb » Mon Nov 13, 2017 11:34 pm
In my view the problem is not the GCode, it is the fact that no message is shown for the problematic geometry.
You have a final depth of 0 and a clearance height of 24. If for some reason some geometry cannot be handled that is all what is left: Move down and up again.
Postby chrisb » Mon Nov 13, 2017 11:53 pm
I investigated your model further: If you perform a "recompute all" there are errors shown in the model. This might be due to different versions but I don't think so. Perhaps the problem is out of the scope of Path Workbench.
