BOLTS Open Library of Technical Specifications
Re: BOLTS Open Library of Technical Specifications
For me https://www.bolts-library.org/ is no longer available. Could someone confirm this ?
Yes. German text means: connection not secure, blocked.bernd wrote: ↑Tue Oct 10, 2017 7:46 am For me https://www.bolts-library.org/ is no longer available. Could someone confirm this ?
thomas
His certificate expired probably...
confirmed. it's down
Hi Bernd,
I'm also getting the same error message in V 0.16, this started to happen after I've Downloaded BOLTS to be used in V 0.17.
I Realized both versions are using the BOLTS file under the Users\AppData\Roaming\FreeCAD folder.
So the questions I have is:
1) Will BOLTS be fully functional for V 0.16?
2) Is it possible to have two folders for each version in the Users\AppData\Roaming\FreeCAD folder? Because when I get a add-on for one version it shows on the other.
ex:
Users\Tim\AppData\Roaming\FreeCADv0.16
Users\Tim\AppData\Roaming\FreeCADv0.17
You can start FreeCAD with parameters for the directories:
Generic options:
-v [ --version ] Prints version string
-h [ --help ] Prints help message
-c [ --console ] Starts in console mode
--response-file arg Can be specified with '@name', too
--dump-config Dumps configuration
--get-config arg Prints the value of the requested configuration key
Configuration:
-l [ --write-log ] Writes a log file to:
/Users/cb/Library/Preferences/FreeCAD/FreeCAD.log
--log-file arg Unlike --write-log this allows logging to an
arbitrary file
-u [ --user-cfg ] arg User config file to load/save user settings
-s [ --system-cfg ] arg System config file to load/save system settings
-t [ --run-test ] arg Test case - or 0 for all
-M [ --module-path ] arg Additional module paths
-P [ --python-path ] arg Additional python paths
--single-instance Allow to run a single instance of the application
No, you probably have an icon to start FreeCAD. There you can add parameters in the properties. As an alternative you can start a shell - "cmd.exe" is its name on windows - and start FreeCAD from there. Don't forget the complete path to the FreeCAD binary.
There was an issue posted about it and jreinhardt replied: https://github.com/jreinhardt/BOLTS/issues/176bernd wrote: ↑Tue Oct 10, 2017 7:46 am For me https://www.bolts-library.org/ is no longer available. Could someone confirm this ?
On 17 Oct 2017 jreinhardt wrote:That is related to OpenShift shutting down version 2 of their service. I will try to migrate the Website to Openshift V3.
BOLTS repos on github moved to an organisation ... https://forum.freecadweb.org/viewtopic. ... 10#p308558
