BooleanFragments error Tool shape is null
unrouted
Postby unrouted » Wed Jan 10, 2018 9:10 pm
Hello,
i want to make an FEM simulation.
As example i created two rectangle plates with 35um thickness and an 1,5mm hight pipe (r1=0,3mm, r2=0,335mm) which connects this two drilled plates. An additional cylinder as heat source was also available.
I want to make an BooleanFragments (Compsolid) before generating mesh and get the following errors.
The errors depend on selection order. And after some trys with "abort" past error message all selected bodies are deleted!
So what's wrong with my model or process?
Thanks!
Version: 0.17.12920 (Git)
Hash: 8faa9f38bb70a598afc2bc39ea1645d416ab057e
Python version: 2.7.8
OCC version: 7.1.0
test_FEM_durchkontakt2.FCStd
(42.56 KiB) Downloaded 10 times
DeepSOIC
Re: BooleanFragments error Tool shape is null
Postby DeepSOIC » Wed Jan 10, 2018 10:32 pm
Hi!
Copper_Bottom body is your trouble. It has empty Tip property, and hence null shape.
Switch to PartDesign wb, right-click Pocket and pick Set Tip from context menu. After that you should be good to go.
unrouted
Postby unrouted » Sun Jan 14, 2018 9:59 pm
Hi
thanks!
This was the solution...
Don't know why the tip was gone.
jmaustpc
Postby jmaustpc » Mon Jan 15, 2018 2:09 am
Hi
thanks!
If you start again, recreating your model from scratch, can you get the Copper_Bottom Body to not have a tip? If so can you provide a step by step way to produce this error?
There has been another post sometime ago where they ended up without a "tip" for no known reason. I am wondering if there is an obscure bug or if there is some user way to remove a tip altogether.
Postby chrisb » Mon Jan 15, 2018 7:25 am
This is in fact a model which might help finding the bug because it is so simple. Please consider if you have done one of the following
- Copper_bottom had more features and you have deleted some of them?
- Of what type where they, did you have one of the patterns involved (linear, polar, mirror)?
- Did you reassign Sketch001 to a face in between?
- Did you use Reorient Sketch?
It might be of interest that Sketch001 is not attached to a face of the Pad but to XY plane.
Postby chrisb » Mon Jan 15, 2018 7:32 am
BTW and for your next model: you could have put both sketches into one, they are not too complicated. Glad you didn't here because we thus have a chance to find the error.
Postby chrisb » Mon Jan 15, 2018 7:40 am
This is how I can reproduce it:
- Create Body
- Create Sketch, attached to XY plane
- Create Sketch001, attached to XY plane
- Pocket, Tip is ok
- Delete Pocket
=> Tip has gone
To reproduce simply delete the last pocket in the attached file.
noTipToday.FCStd
(9.31 KiB) Downloaded 7 times
Postby chrisb » Mon Jan 15, 2018 9:08 am
Should I create a ticket?
Postby chrisb » Mon Jan 15, 2018 9:12 am
Since it had already been downloaded: I simplified the model and the process of showing the error in my previous post.
DeepSOIC
Postby DeepSOIC » Mon Jan 15, 2018 9:58 am
yes
