Hello AltoRoos,
welcome to the Freecad-forum.
You must use the clip-filter in paraview with the options shown in the picture.
Then save file as vtk multiblock, enable "write all timesteps as file-series".
In FC you can import the vtu-files with the FEM-results filter. The meshes are
located in the result container. Gift has written to different macros. The first one is for
meshes NOT located in the result container. Use the second one. Workflow:
Import meshes, create a group, put all meshes in, hide all meshes.
Click on group in model tree, run macro. I personally prefer to use "save animation" in paraview
(use more than 30 frames per second), that gives a better "splash". BTW: export the cube
as stl and load it in paraview (you must scale the stl to 0.001) and adjust the opacity.
regards Thomas
- clipfilter.JPG (84.24 KiB) Viewed 894 times
- fallingDrop.gif (393.88 KiB) Viewed 894 times
