Command panel
Moderator: agryson
triplus
Re: Command panel
Postby triplus » Tue Nov 21, 2017 4:19 pm
Control panel front and back end features
  • Workbench selector combo box
  • Reset workbench settings to defaults
  • Set default menu check box
  • Workbench menu combo box
  • Add or remove workbench menu
  • Small UX related adjustments and tweaks
  • UUID based group/menu storage
  • Default, new, find and delete group (menu)
  • Shared widgets created on demand
  • Artwork
triplus
Re: Command panel
Postby triplus » Mon Nov 27, 2017 8:51 pm
Enabled commands panel
  • Add, remove and move (enabled) command buttons
  • Add command on double click
  • Always show (default) icon for command
  • Always show not currently available commands in enabled panel
  • Use disabled icon mode for not available commands
  • Add tooltips for available and enabled commands
  • Artwork
triplus
Re: Command panel
Postby triplus » Wed Nov 29, 2017 5:34 pm
Workbench buttons
  • Flow layout
  • Scroll wheel event filter for disabled buttons
  • Unavailable command name info added to tooltip
  • Create workbench buttons from command names
  • Show workbench buttons on workbench activation
  • Update workbench buttons on preferences edit
  • Predefined set of commands for default workbench menu
triplus
Re: Command panel
Postby triplus » Sat Dec 09, 2017 11:54 pm
Menu, spacer and separator
  • Create and edit buttons with menu
  • Create separators
  • Create spacers
  • Artwork
triplus
Re: Command panel
Postby triplus » Fri Jan 05, 2018 4:47 pm
  • Expand or collapse menu
  • Persistent button and menu default action
  • Set default menu action only if action was triggered from the menu
  • Rework existing artwork to omit Qt SVG support related messages
  • Artwork
triplus
Re: Command panel
Postby triplus » Tue Jan 23, 2018 11:38 pm
Settings
  • Settings section added to the preferences
  • Button style control (icon, text, icon and text, text below icon)
  • Button auto raise control
  • Button icon size control
  • Button text size control
  • Button width control
  • New expand layout option
  • Minor tweaks
Re: Command panel
Postby Kunda1 » Tue Jan 23, 2018 11:45 pm
Nice job!
silopolis
Re: Command panel
Postby silopolis » Fri Jan 26, 2018 6:41 am
Kunda1 wrote:
Wed Oct 11, 2017 12:30 am
@triplus perhaps adding instructions on how to install Command panel will encourage testing...?
I'd love to be able to add repository URLs in addons manager to add custom modules and then use manager goodness to update and remove them.
pablogil
Re: Command panel
Postby pablogil » Fri Jan 26, 2018 7:23 am
I also miss other nice @triplus modules in "addon manager" such as Selector... Could you add them so that all the community has a easier access to install, try and love them? :)
PS - how is going Piemenu 2.0? I'm still missing it... :roll:
triplus
Re: Command panel
Postby triplus » Fri Jan 26, 2018 11:29 pm
Done:
https://github.com/FreeCAD/FreeCAD-addons/issues/64
  • Command panel: Small set of additional refinements and a feature or two
  • Command panel: Providing an API for adding workbench menus from Python and tackling that in Preferences
  • TabBar: Removing functionality that has evolved and is now located in separate modules
  • PieMenu
Note that a lot of command panel functionality and principles will be reusable in PieMenu.
P.S. There is a small issue in light set of stylesheets regarding Selector toolbar. I was hopping you could take a look at it before FreeCAD 0.17 release. That would come down to one less item on the todo list on my side. ;)
