Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by bernd »
Which constraint do you like to apply. We may could do a hack, just to get it useble to make this example?
thschrader
Post by thschrader »
bernd wrote: Wed Jan 24, 2018 5:00 pm I would just be speed up things a lot if we would only display one arrow per face, but this can not be adjusted ATM.
Lets colour the faces, no 3D-arrows. Mhh...lets say when thre are more than 100 faces to display...
polymer
Post by polymer »
I think a combination whould be good, color to Show which Face belong to the contrain and a Limited number of arrows.
TT-RS
Post by TT-RS »
For me, it is the most interesting workbench in FC, very interesting and promising.
oliveroxtoby
Post by oliveroxtoby »
TT-RS wrote: Tue Feb 06, 2018 6:14 pm For me, it is the most interesting workbench in FC, very interesting and promising.
Thank you for the support! :-)
sket
Post by sket »
hello, I'm trying to add the workbench, when I check the dependencies I have this result:
Checking dependencies...
Paraview executable paraview not found in path.
when I installed OpenFoam, this install also Paraview. I found the folder of Paraview in /opt.
what should I do? how should I proceed?
edit: please some help.
oliveroxtoby
sket wrote: Sun May 13, 2018 10:23 am hello, I'm trying to add the workbench, when I check the dependencies I have this result:
Sorry - missed this post. The easiest way would be to add a symlink to the paraview executable to one of the bin directories in your path - say /usr/local/bin - with a command like
ln -s /opt/paraview/bin/paraview /usr/local/bin/paraview
sket
Post by sket »
oliveroxtoby wrote: Fri Jun 08, 2018 12:19 pm
thank you Oliver!
Crossleyuk
Post by Crossleyuk »
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
I am relatively new to FreeCAD (six months) but can now use it reasonably well after great support from the Forum. I am now looking to move forward into a piece of research (MPhil) and need to use CFD, so CfdOF has been a fantastic start.
I have it all up and running and started with the initial "Elbow" tutorial after going through the Read Me.
CFD Tutorial 1 - Elbow Rev 2.FCStd
(340.26 KiB) Downloaded 47 times
I am also seeing different dialogues to those illustrated in the turorial with failures as indicated by this dialogue:
Elbow Tutorial Mesh Response - Rev P1.PNG (23.21 KiB) Viewed 1926 times
And others saying:
Response after start of Meshing
0.0: Starting meshing ...
0.1: Exporting mesh region data ...
0.4: Exporting the part surfaces ...
0.5: Running gmsh ...
7.5: ./Allmesh: line 6: [: too many arguments
7.7: tee: log./c/Program: No such file or directory
7.7: tee: Files/FreeCAD: No such file or directory
7.7: tee: 0.17/bin/gmsh.exe: No such file or directory
7.8: tee: log./c/Program: No such file or directory
7.8: tee: Files/FreeCAD: No such file or directory
7.8: tee: 0.17/bin/gmsh.exe: No such file or directory
26.6: Meshing completed[/color]
and
Response from Solver Run (3D Mesh)
0.0: Checking dependencies...
0.0: OpenFOAM case writer is called
0.9: Error writing case:
0.9: [Error 3] The system cannot find the path specified:'c:\\uappdata\\local\\temp\\meshCase\\constant\\triSurface/*.*'
0.9: Write case setup file failed
sers\\user\\
Sorry, very inexperienced in the Forum and don't understand what is going on here. Could you please direct me to some further assistance.
oliveroxtoby
Crossleyuk wrote: Tue Jan 15, 2019 6:06 am
And others saying:
Could you update the workbench and check it again? I ran into the same issue recently and could have sworn I had fixed it. Let me know if that doesn't help.
