Disappearing face after cut of two objects
Dear Freecad Community,
I have an issue with "Make a cut with two shapes".
I want to create coupler D25L30 5mm to 10mm and figure is almost done. I just need to cut sweeped helix with finished cylinder,
but after this operation outer shape is disappearing.
Please find attached image before cut operation Helix.png and after operation Output.png
In addition I am attaching whole project.
Regarding version of Freecad the project was created with latest Freecad 0.16 but then I have downloaded and compiled latest version from github 0.17 13280 (Git) but the issue is the same.
I am using unix version under Debian Stretch
Thank you in advance for any help.
- coupler_5_to_10mm.FCStd
- (196.86 KiB) Downloaded 66 times
- Output.png (21.83 KiB) Viewed 2451 times
- Helix.png (25.48 KiB) Viewed 2451 times
Re: Disappearing face after cut of two objects
Hi Dyleks, welcome to the forum,
For your first design I think this is a very good start.
The problem of cutting the sweep from Cut004 is as we call it a coplanar problem.
Sketch002 what is the base of the sweep is on the cutline in cut004.
Rotate sketch002 19degrees to the start of the helix and you get a valid Cut005
Hi Willem,
thank you for you fast and clear answer.
Now I understand it worked awesome !
Unfortunately I have again the same issue :/
I tried to create the same part from the beginning in Freecad 0.17 with this new features but I have still the same error, and I cannot findout where is this issue with "coplanar problem". Is there any possibility to highlight this issue or how to debug it ?
Thanks for any help.
- BR_5x10_D25L30.fcstd
- (233.67 KiB) Downloaded 34 times
Hi, perhaps this video give you some help on the technique to rotate the sketch.
Hello dyleks, can you post the full "About FreeCAD" info as explained here: http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
The OCCT/oce version is very relevant. It won't change anything but recent versions of the geometry kernal offer some improvements. And future versions promise more improvements.
"fight the good fight"
Dear Willem,
I do know how to rotate sketch and in newly attached file you can see that the base of the sweep is not on the the cutline anymore but it still do not work properly. I have also rotated base points of cylinder but it do not help neither :/
Hi, I did not download yesterday your second Freecad drawing, now I did.
You made a helix and in a body you made a sketch and a shapebinder to the helix. This is a correct way of working . Next you did a sweep in the part workbench. This is not good. In the dependency graph the lines for this sweep are red as a warning. You should use the additive pipe function in the part design workbench for making a sweep.
If you want to use the sweep function in the part workbench it is better to make a sketch in the sketcher workbench and not in the part design workbench
The cylinder is built without using the part design workbench and is not in a body. My advice is to rebuilt it in a body. In that case the subtracting pipe function can be used for cutting material from the cylinder.
Here a video about using the additive pipe function, but again I strongly recommend you to built the cylinder also in the part design workbench
Sorry for bothering again, but I tried every step by step as it is on your last video and it do not work for me. The result is the same
If you are so kind please look to attached file it just need to do cut, all previous steps are already done. The dependency graph looks like yours on video. Maybe there is an issue with version I am using ?? (from github 0.17 13280)
- (410.33 KiB) Downloaded 55 times
No, the issue is that you do not understand the new 0.17 work flow. You should not use Part Booleans on separate Bodies if your intent is to have one single solid part. Everything can be done in one single Body, with only PartDesign features.
Sorry but I'm short on time and cannot detail further.
