ShortCuts
Re: ShortCuts
Postby yorik » Sat Apr 29, 2017 4:09 am
Done, it's added now
triplus
Re: ShortCuts
Postby triplus » Sat Apr 29, 2017 3:45 pm
yorik wrote:Done, it's added now
Thanks.
DuckDuckGoose
Re: ShortCuts
Postby DuckDuckGoose » Thu Aug 03, 2017 8:13 pm
Hi triplus... can this be used to get a list of already-existing shortcuts?
triplus
Re: ShortCuts
Postby triplus » Fri Aug 04, 2017 7:58 am
Not yet.
zbigg
Re: ShortCuts
Postby zbigg » Tue Feb 13, 2018 1:43 pm
Is that INVOKE KEY really necessary?
Or might be rather toggled on/off for good?
cheers,
triplus
Re: ShortCuts
Postby triplus » Tue Feb 13, 2018 4:41 pm
In the current implementation it is a key feature.
Having it always on. You would still need to press on an invoke key to change the focus. Likely provided as a dock widget as seen with Launcher:
https://github.com/triplus/Launcher
Having it always off. That is to work in the same way. Just not to see the visual feedback. I had some prototypes for such behavior too. But in the end i settled for having a visual feedback and only when invoked.
Reference:
https://forum.freecadweb.org/viewtopic.php?f=3&t=26895
zbigg
Re: ShortCuts
Postby zbigg » Tue Feb 13, 2018 7:47 pm
Auxiliary command line, sth like in Autocad would not be bad...?? /do not forget to enable resizing for that window/pane for browsing command history/
cheers,
triplus
Re: ShortCuts
Postby triplus » Wed Feb 14, 2018 1:49 pm
Thanks for the suggestion. But for now i don't plan to expand a list of the projects i am working on regarding FreeCAD. Finalizing existing ones is the only goal i have ATM.
Re: ShortCuts
Postby Kunda1 » Wed Feb 14, 2018 3:07 pm
Auxiliary command line, sth like in Autocad would not be bad...?? /do not forget to enable resizing for that window/pane for command history/
It's a good idea, open a feature ticket for it
wandererfan
Re: ShortCuts
Postby wandererfan » Fri Feb 16, 2018 1:28 pm
Isn't the python console a big command line?
cron
