Discussion on Dressups and Tool Controllers
bill
Postby bill » Thu Mar 01, 2018 4:38 am
Edit: This discussion was split and is a continuation of https://forum.freecadweb.org/viewtopic. ... 17#p217663
sliptonic wrote:
Wed Feb 28, 2018 7:46 pm
I've added a new ticket in Mantis: https://www.freecadweb.org/tracker/view.php?id=3358
This is a hard crash of freecad and fully reproducible. Advice?
The crash appears to be happening because the simulation can't find the associated tool controller. The dress-up doesn't have its own TC but uses the TC of the base operation. Simulation should take this into account.
This sounds more like it is a problem of the Dress-Up; No!
It (Dress-Up) needs to provide/declare a tool-controller just like any-other operation I would think.
Re: CAM simulation for the Path Workbench
Postby chrisb » Thu Mar 01, 2018 7:12 am
From a technical point: yes. The Dress-Up should be able to tell which tool it uses. From a users point of view: no. So it should always be the tool of the path which is dressed up. Otherwise it's not a Dress-Up, it's an operation on its own.
herbk
Postby herbk » Thu Mar 01, 2018 7:47 am
+1
Gruß Herbert
schnebeck
Postby schnebeck » Thu Mar 01, 2018 9:25 am
Hiho,
another Simu-bug I notice:
When you create multiple jobs based on different solids you get a job selector in the simulation tool. If you do not select the first job the stock for setting up the cut material is still taken from the first job.
Bye
Thorsten
Simu-2parts.fcstd
(41.1 KiB) Downloaded 24 times
sliptonic
Postby sliptonic » Thu Mar 01, 2018 4:04 pm
Hiho,
Bye
Thorsten
Confirmed. added issue #3359
bill
Postby bill » Thu Mar 01, 2018 5:15 pm
Dont follow the yes and no; hopefully the user knows what they are doing using a dress-up.
Whether the TC is declared, retrieved, inherited, lifted, pinched, or extracted, from the Base-Operation, the Dress-Up Operation needs to look like any other operation; too bad there is no interface specification/design docs; just pure-code I guess.
Excluding the data structure, the Dress-Up is simply/only an insertion of path segments
Thus, the Sim process all ops the same.
Havent used Sim for a while and I am not on the latest daily due to past problems with coding/structure/architecure surprises:
Are Drilling ops working nowadays ; Non-Response to button clicks still?, Large-Volume-Objects (yea. your can dial-down the parameters and get by; most testing seems to occur on smaller objects; might be good idea to check initial volume and dial-down automatically and/or alert user with suggestion) blowing up still?; Seems like it runs to completion without relinquishing control to its environment -- not a good thing !
Is the latest daily pretty-much safe on Linux platforms???
All in all, the PATH-Simulation Tool kicks a$$ for as NEW as it is!
Postby chrisb » Thu Mar 01, 2018 5:45 pm
+1
sliptonic
Postby sliptonic » Thu Mar 01, 2018 6:22 pm
Not quite. A dressup modifies an existing path which has a tool controller already. From a user's point of view, it would be wrong to add a TC to the dressup. When it comes to implementation, it might be appropriate to copy the base operation TC but it should not a changeable property of the dressup. In this sense, a dressup is different from an operation.
Insertion/modification/deletion
Again, from a user's point of view, I agree. The question in my mind is whether we should modify all dressup operations to have a tool controller and then prevent the user from seeing/changing that tool controller just so simulation can treat dressups and operations the same. Or, should simulation be modified to check for the type of operation and if it's a dressup, retrieve the TC from the parent operation.
As far as I know, drilling is working perfectly. I don't understand all the other points you raise. We're trying to stabilize Path for 17 release and all bugs in the tracker except the two I just entered, have been closed.
I think it's all good on linux (except the sim crash) I agree about the ass-kicking nature of Simulation. :lol:
JoshM
Postby JoshM » Thu Mar 01, 2018 6:40 pm
On the topic of Dressups, the bigger confusion to my mind--and I've mentioned it before--is that the moment you add a Dressup, it moves to the bottom of the Job workplan. I cannot see any upside to this, and a LOT of potential issues...
sliptonic
Postby sliptonic » Thu Mar 01, 2018 6:47 pm
I agree. That's a problem. Want to add a bug?
