Wrong placement on simple copy of object inside parts in v 0.17
galou_breizh
Post by galou_breizh »
Hello,
I may have discovered a bug in simple copy of objects inside parts in v0.17. In the attached file, I tried three methods to show the bug:
- "Part / Create simple copy"
- "Draft / Clone"
- Ctrl-C + Ctrl-V
after having selected a cube with a non-null placement inside a part with a non-null placement.
It looks that the part placement is ignored during the copy.
Cf. attached file.
Any comments? Thanks!
Gaël
bug_simple_copy.fcstd
(13.8 KiB) Downloaded 44 times
easyw-fc
Re: Wrong placement on simple copy of object inside parts in v 0.17
Post by easyw-fc »
galou_breizh wrote: Wed Feb 28, 2018 2:38 pm Hello,
- "Draft / Clone"
- Ctrl-C + Ctrl-V
Cf. attached file.
Gaël
this is a known issue ... simple copy ATM doen't work with PDN
I posted already a mantis bug request
https://www.freecadweb.org/tracker/view.php?id=2905
unfortunately it is still unassigned
galou_breizh
Thanks for the quick reply. I must have searched the forum with the wrong keywords because I hadn't found anything.
In the meantime, I wrote a macro to work around this problem:
__Name__ = 'Deep Copy'
__Comment__ = 'Takes a part and makes a compound out of it'
__Web__ = ''
__Wiki__ = ''
__Icon__ = ''
__Help__ = 'Select a part and launch'
__Author__ = 'galou_breizh'
__Version__ = '0.1'
__Status__ = 'Beta'
__Requires__ = ''
from freecad import app
from freecad import gui
def deep_copy(doc):
    for sel_object in gui.Selection.getSelectionEx():
        deep_copy_part(doc, sel_object.Object)
def deep_copy_part(doc, part):
    if part.TypeId != 'App::Part':
        # Part is not a part, return.
        return
    copied_subobjects = []
    for o in get_all_subobjects(part):
        wrong_types = [
                'App::Origin',
                'App::Plane',
                'App::Line',
        if o.TypeId in wrong_types:
            continue
        copied_subobjects += copy_subobject(doc, o)
    compound = doc.addObject('Part::Compound', 'Copy of ' + part.Label)
    compound.Links = copied_subobjects
    doc.recompute()
def get_all_subobjects(part):
    """Recursively get all subobjects"""
    l = part.OutList
    for o in l:
        l += get_all_subobjects(o)
    return l
def copy_subobject(doc, o):
    gui_doc = gui.getDocument(doc.Name)
    gui_o = o.ViewObject
    copied_object = []
    try:
        copy = doc.addObject(o.TypeId, o.Name)
        copy.Shape = o.Shape
        copy.Label = 'Copy of ' + o.Label
        copy.Placement = get_recursive_inverse_placement(o).inverse()
        gui_copy = copy.ViewObject
        gui_copy.ShapeColor = gui_o.ShapeColor
        gui_copy.LineColor = gui_o.LineColor
        gui_copy.PointColor = gui_o.PointColor
        gui_copy.DiffuseColor = gui_o.DiffuseColor
    except AttributeError:
        pass
    else:
        copied_object = [copy]
    return copied_object
def get_recursive_inverse_placement(o):
    # We browse the parent in reverse order so we have to multipy the inverse
    # placements and return the inverse placement.
    # Note that we cannot rely on o.InListRecursive because the order there is
    # not reliable.
    p = o.Placement.inverse()
    for parent in o.InList:
        if parent.TypeId == 'App::Part':
            p = p.multiply(get_recursive_inverse_placement(parent))
            break
    return p
if __name__ == "__main__":
    doc = app.activeDocument()
    deep_copy(doc)
I also add the missing information:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.13335 (Git)
Build type: None
Hash: 8aad83f08f7a9e4da9c42b42d14f4ff514ee93c6
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Gaël
galou_breizh wrote: Wed Feb 28, 2018 2:38 pm I may have discovered a bug in simple copy of objects inside parts in v0.17.
And there is - also known - one more of this kind: Behaviour is similar with a ShapeBinder. My current workaround is to use Expressions to assign the Placement of the Part to the copy. That makes the copy move together with the Part.
easyw-fc
Post by easyw-fc »
galou_breizh wrote: Wed Feb 28, 2018 4:43 pm Thanks for the quick reply. I must have searched the forum with the wrong keywords because I hadn't found anything.
Gaël
Hi Gaël
nice macro...
I have a similar approach with a recursive placement in my kicadStepUp WB...
I modified a bit the macro to manage Part in Part (and for example in a hierarchical STEP) and keep transparency
__Web__ = ''
__Wiki__ = ''
__Icon__ = ''
__Version__ = '0.2'
__Status__ = 'Beta'
__Requires__ = ''
make_compound = True #False
import FreeCAD as app,FreeCADGui as gui
# from FreeCAD import app
# from FreeCAD import gui
def deep_copy(doc):
        return
        wrong_types = [
                'App::Origin',
                'App::Plane',
                'App::Line',
                'App::Part'
            continue
    if make_compound:
        compound = doc.addObject('Part::Compound', part.Label+'_copy')
    doc.recompute()
    l = part.OutList
    for o in l:
    return l
    copied_object = []
    try:
        #copy.Label = 'Copy of ' + o.Label
        copy.Label = o.Label+'_copy'
        gui_copy.Transparency = gui_o.Transparency
        pass
    else:
    # not reliable.
            break
    return p
    deep_copy(doc)
It would be nice to have it also working with Body objects ...
Maurice
galou_breizh
Maurice, you probably mean something else than I think because part in part were already supported (a useless copy of parts was done, that's true). Anyway, thanks for your contribution.
Here is a version of the macro that also supports bodies, compounds, and results of boolean operations.
__Web__ = ''
__Wiki__ = ''
__Icon__ = ''
__Version__ = '0.3'
__Status__ = 'Beta'
__Requires__ = 'FreeCAD > v0.17'
def deep_copy(doc):
        return
    doc.recompute()
def get_all_subobjects(o):
    Subobjects of objects having a Shape attribute are not included otherwise each
    single feature of the object would be copied. The result is that bodies,
    compounds, and the result of boolean operations will be converted into a
    simple copy of their shape.
    if hasattr(o, 'Shape'):
        return []
    # With the assumption that the attribute InList is ordered, only add the
    # subobject if o is the direct parent, i.e. the first in InList.
    l = [so for so in o.OutList if so.InList and so.InList[0] is o]
    for subobject in l:
        l += get_all_subobjects(subobject)
    return l
    copied_object = []
    if not hasattr(o, 'Shape'):
    vo_o = o.ViewObject
    try:
        copy = doc.addObject('Part::Feature', o.Name + '_Shape')
        vo_copy = copy.ViewObject
        vo_copy.ShapeColor = vo_o.ShapeColor
        vo_copy.LineColor = vo_o.LineColor
        vo_copy.PointColor = vo_o.PointColor
        vo_copy.DiffuseColor = vo_o.DiffuseColor
        vo_copy.Transparency = vo_o.Transparency
        pass
    else:
    # not reliable.
    # TODO: see if this cannot be replaced with o.getGlobalPlacement().
    parent = o.getParentGeoFeatureGroup()
    if parent:
    return p
    deep_copy(doc)
Gaël
easyw-fc
Post by easyw-fc »
galou_breizh wrote: Thu Mar 01, 2018 9:28 am Maurice, you probably mean something else than I think because part in part were already supported (a useless copy of parts was done, that's true).
the useless 'Part' was what I meant :D
galou_breizh wrote: Thu Mar 01, 2018 9:28 am Here is a version of the macro that also supports bodies, compounds, and results of boolean operations.
Gaël
thanks... this should be included to useful FC Macros ;)
https://www.freecadweb.org/wiki/Macros_recipes
I'm attaching an icon that could be used (same color of Part DN icon)
deep_copy.svg
(15.01 KiB) Downloaded 150 times
easyw-fc
Post by easyw-fc »
Gaël
Hi Gaël,
I've found a case where Body seems not to be copied correctly...
I'm attaching the file:
Body-in-Part-failing.FCStd
(43.85 KiB) Downloaded 39 times
'Spacer' is working, 'MainPart' is not.
Thank you for having a look at
Maurice
galou_breizh
This happens because the tip of Body001 is not set (i.e. the attribute shape of Body001 is present but the call to isNull() returns True).
I improved the macro so that is this situation, the shape of the body will not be copied.
I'll put the macro on the Macro Recipies page if you feel it's worth it.
Gaël
easyw-fc
Post by easyw-fc »
galou_breizh wrote: Thu Mar 15, 2018 8:24 am This happens because the tip of Body001 is not set (i.e. the attribute shape of Body001 is present but the call to isNull() returns True).
Gaël
I think this should be placed on Macro Recipes... :)
Moreover I consider this macro so useful that could be included in Part Design WB Menu as 'Deep Copy with recursive Placement' :D
Very useful for i.e. 3D printing ;)
Please post here when you have placed the macro in recipes...
Thx
Maurice
