Thank you for your comments questions
What do you mean by that...?by chrisb » Thu Mar 01, 2018 7:33 am
No time to test now. Is it Body and Part aware?
if you select an edge of a cube you can generate a mid point,
if you select a face of a cube you will generate mid points for all edges of the face and
if you select a cube you will generate all mid points for all edges
This is what you mean?
Will test.by HarryGeier » Thu Mar 01, 2018 8:47 am
Did not manage to get lines to show up.
Thank you
Could you explain what you mean? I do not know what is a "shapebinder".by HarryGeier » Thu Mar 01, 2018 8:47 am
Then i was not able to move elements or sets into a body, only to the top level of the part . It´s possible to create a shapebinder from each object and access the element via the shapebinder..
Never tested on 17. but i will and fix if any issue.by HarryGeier » Thu Mar 01, 2018 8:47 am
unless i am not missing something.. not for 0.17 as it is..
@rentlau_64 .. was it ment to work in .17 ?? if not you should please clearly state that
I Didn't test on Window 10...I can test it on Windows 8 if needed...let me know.by hammax » Thu Mar 01, 2018 9:14 am
...Win10-32 and FC0.17.13340.
Addonmanager is not able to upload/install WorkFeatureWB.
A problem I encounter since I use FC.17.
(I suppose it has something to do with Linux-resistance of Win....)
For me it is normal, WF_WB is not yet referenced into AddOn Manager, Please use manually install now as described into Repository "Readme" as Triplus and Sgrogan said.
Yes this is a true Workbench and yes It can work on side of original WF MACRO.
Thank you and have a nice day
Rentlau
