Work Feature workbench with parametric objects
mario52
Re: Work Feature workbench with parametric objects
Post by mario52 »
hi
no problem
rentlau_64 wrote: Sun Mar 18, 2018 7:10 am Get the archive from Git :https://github.com/Rentlau/WorkFeature-WB
And unzip into your home directory /home/your_rname/.FreeCAD/Mod/
WorkFeature (macro)
WorkFeature-WB (workbench)
Version: 0.17.13387 (Git)
Hash: c5f4079252b11e3c54cd603be7d3697fa9f9d922
Python version: 2.7.14
OCC version: 7.1.0
Version: 0.16.6712 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
i prefer WorkFeature (macro) always available, always on hand, thanks rentlau_64
mario
rentlau_64
Post by rentlau_64 »
Hi, GlouGlou
I Tested the installation on Windows 8 and didn't get any problem,
The Workbench is available on the Workbench Menu.
I unzip the file from Github under :
C:\Program Files\FreeCAD 0.16\Mod\WorkeFeature-WB-master
And few usage tests were positive too.
What is the exact procedure you followed to install?
Rentlau_64
Vincent B
Post by Vincent B »
By copying manually the directory, its working now... sorry about that. ;)
Post by yorik »
the workfeature WB is now part of the addons repo.
I had to make some git sorcery to rename the workfeature macro repo, tell me if you notice any problem.
rentlau_64
Merci Yorik,
I will keep you inform if i detect some issue.
Have a nice day
Rentlau_64
hammax
Post by hammax »
...thanks, now the WorkfeatureWB is installable without problems via addonmanager
on (my) Win10-32 under FC.17.13429
and usable.
https://forum.freecadweb.org/viewtopic. ... 95#p217771
HarryGeier
Post by HarryGeier »
hammax wrote: Fri Mar 23, 2018 9:36 am ...thanks, now the WorkfeatureWB is installable without problems via addonmanager
and usable.
How do you then bring them into a Sketch ??
i must select each object and import via shapebinder..
I tried to move all, set, objects .. into a body..no way...
rentlau_64
@ realthunder
Thank you for your trick regarding linksubglobal : It seems it fix my issue.
@ HarryGeier
I am currently fixing the "PartDesign Body" issue and hope to deliver soon a new fix.
What do you mean : You would like to transform the WF_WB parametric object into a Sketch object and keep the parametric behavior?
Thank you for your comment
Have a nice day
Rentlau_64
HarryGeier
Sure.. what else should i want to do with them , other than reference them as external geometry in a sketch ?
Same as i do with datum_geometry of the elements from the workfeature_macro
rentlau_64
Hello,
New release of the WorkFeature Workbench, compatible with Qt5 and py3 is now available here:
Enjoy ! :D
Rentlau
