Creating wall freezes 3D view
Dgingrey
Postby Dgingrey » Wed Apr 04, 2018 5:16 pm
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.13488 (Git)
Hash: 2891173923bcecaace64e0544f5773facbdef436
Python version: 2.7.14
OCC version: 7.0.0
When I try and make a wall using the FreeCad version listed above the 3D viewing pane freezes up, that is I cannot manipulate the 3D view in any way. I draw a rectangle
and after selecting it, press the Wall button. The wall shows up in the combo view but not in the 3D view.
Wall from rectangle.PNG (21.62 KiB) Viewed 650 times
The 3D view cannot be manipulated until I delete the wall from the combo view. Then the 3D view can again be changed.
I saved the file and opened it using FreeCad v17.7745
Version: 0.17.7745 (Git)
Hash: 79dcdfbc782e24bb34db882143af7ce8ebd237bd
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
As you can see the wall was formed and the 3D view is manipulated.
Wall from rectangle 7745.PNG (29.83 KiB) Viewed 650 times
I have tried installing v17.13488 on four different computers running Windows 10 32 bit and I get the same results on each machine.
Has anyone else experienced this problem?
Wall.FCStd
(6.9 KiB) Downloaded 16 times
damian
Re: Creating wall freezes 3D view
Postby damian » Wed Apr 04, 2018 7:34 pm
Here all work fine
OS: Ubuntu 16.04.4 LTS
Version: 0.17.13498 (Git)
Build type: None
Hash: 85b42a16d960c4ca11dbb8288ad08cf12a0291dc
Python version: 2.7.12
OCC version: 7.1.0
1º) Edit - Preferences - Outputwindow: mark redirect internal python output/errors to report view
2º) View - panels - report view
3ª) Inform about error messages
Dgingrey
Postby Dgingrey » Thu Apr 05, 2018 3:13 pm
I also tried it on a machine running windows 7 32 bit and it worked fine.
It seems the problem occurs under windows 10 32 bit.
I tried replacing the file "ArchWall.PY" from v17.13488 with the file from v17.7745. This fixed the 3D viewing problem but
unfortunately caused other problems so it looks like something in the file "ArchWall.PY" is causing the problem.
Dgingrey
Postby Dgingrey » Wed May 23, 2018 8:59 pm
I was incorrect when I said it looks like the problem only occurs on Windows 32bit machines. I upgrade from Windows 32 bit to Windows 64 bit
and experienced the same error. I observed that on every machine where the error occurs I get "Mod\Measure\Initgui.py not found" during
initialization of the program.
INITGUI NOT FOUND.PNG (245.44 KiB) Viewed 480 times
Postby Kunda1 » Sat Aug 25, 2018 11:49 pm
OP can still reproduce: https://www.freecadweb.org/tracker/view ... 423#c11637
Version: 0.17.13528 (Git)
Branch: releases/FreeCAD-0-17
Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b
OCC version: 7.2.0
Version: 0.18.14426 (Git)
Hash: 3927a2ed8b009ab4dfdca53fbebf0060193b67b4
OCC version: 7.2.0
I just tried the latest versions of FreeCad v17 and V18 and got the same results.
Postby wmayer » Sun Aug 26, 2018 5:43 am
It looks like your graphic driver is the culprit. Do you have enabled the experimental VBO rendering in the preferences? If yes, then switch it off.
