Rebar schedules for box culverts
Re: Rebar schedules for box culverts
Postby yorik » Thu Apr 05, 2018 2:03 pm
Joel_graff wrote:
Wed Apr 04, 2018 2:12 pm
You can go to www.idot.illinois.gov, click on "Resources" at the top, then "Manuals and Guides"
Crazy... I still cannot access that address directly, but using a proxy it worked :? Some blocking operation somewhere...
Anyway, this is one more very good example of what we should aim for with Rebars + TechDraw...
Joel_graff
Postby Joel_graff » Sat Apr 07, 2018 3:02 pm
thschrader wrote:
Wed Apr 04, 2018 1:38 pm
No, because it is difficult.
In concrete engineering the structure (lets say a beam) is calculated at the limit state.
In the tension zone the concrete is cracked, you will need special programms to simulate
the cracks with FEM.
I'm generally unfamiliar with FEM, apart from doing manual matrix calculations in college... but a little searching turned up this document:
https://www.google.com/url?sa=t&source ... 9O6Qo[url]
It's a pdf published in 2001 by the Washington Department of Transportation on doing reinforced concrete FEM modeling. They used ANSYS and described the modeling process for a few cases, focused primarily on fiber-reincorced composites (FRP).
I expect the problem is quite complex to solve, but seeing this made me think it's not unapproachable. I see that the key to some of this is being able to specify different materials in layers...
Anyway, I'm generally ignorant of FEM structural workflows, though I have a good understanding of the math that's involved. I'd happily start another thread for it, if it seems like a worthy topic for more discussion.
You can find the FreeCAD Trails workbench for transportation engineering on my github at:
https://www.github.com/joelgraff/freecad.trails
Postby bernd » Mon Apr 09, 2018 6:35 am
a much more simpler example in this regard can be found here: https://forum.freecadweb.org/viewtopic. ... 61#p135030
Rebar schedules would surely something very cool and would make FreeCAD useble for real reinforcement drawings.
Postby Kunda1 » Mon Apr 09, 2018 11:00 am
amrit3701 wrote:ping
Hey @amrit3701 thought you may be interested in this thread ;)
Joel_graff
Postby Joel_graff » Mon Apr 09, 2018 12:45 pm
Implementing that is definitely a good place to start.
chakkree
Postby chakkree » Wed Apr 11, 2018 2:42 am
I'm trying to create rebar schedule dialog(spreadsheet's like) using QTableWidget
Now, it cannot insert new rebar.
and Input rebar dialog has only 3 types.
RebarsSchedule_20180411.zip
(4.38 KiB) Downloaded 20 times
Postby bernd » Wed Apr 11, 2018 5:39 am
How do I run this?
chakkree
Postby chakkree » Wed Apr 11, 2018 6:15 am
How do I run this?
1. Unzip RebarsSchedule_20180411.zip
2. open RebarScheduleSheet.py with FreeCAD
3. Ran macro.
It's not full function, for the first test.
Version: 0.17.13509 (Git)
Branch: releases/FreeCAD-0-17
Hash: 0258808ccb6ba3bd5ea9312f79cd023f1a8671b7
Python version: 2.7.14
OCC version: 7.2.0
Postby yorik » Wed Apr 11, 2018 1:20 pm
Wow that looks very nice! These data could easily be obtained from the model I think...
thschrader
Postby thschrader » Sun May 06, 2018 4:18 pm
@ Joel Graff:
Hi Joel,
I try to design the reinforcement of the rigid-frame-culvert below.
Picture taken from
http://www.bv.transports.gouv.qc.ca/mono/1165314.pdf
The culverts are prefabricated in a factory and then delivered to the construction site.
Is that right? If so, why not connect the V/U/H-rebars to get one rebar?
Whats the minimum concrete cover you must use in USA?
regards Thomas
